mistergrumpy
posted on 9/10/06 at 12:43 PM |
Mounting ZX9
Oo er. Not like that! I've come to one of them annoying stops in my build, the one where you run out of money!, so I was gonna knock up a cradle
for the engine with some bits I have. I put the engine inside the front of the chassis and firstly its a tight squeeze and the drive shaft seems to be
slightly to one side of centre pointing down the transmission tunnel is this right? Is it worth relocating the oil filter so its not rattling up
against the side panel as its real close and lastly what bushes should I use for the upper mounts i.e. the mounts above the main beefy looking one
that has rubber ones already on.
Ta
chockymonster
| posted on 9/10/06 at 02:01 PM |
Bushes? BEC?
My R1 lump is hard mounted, not a rubber bush in site
Coose
| posted on 9/10/06 at 02:06 PM |
I used MNR wishbone mounts and bushes.
Spin 'er off Well...
mistergrumpy
| posted on 9/10/06 at 02:22 PM |
Hard mounted? How does that fare? Do you not get vibrations or premature cracking ot owt? My main mount has bushes with it and was really just
wondering about the other mount.
zxrlocost
| posted on 9/10/06 at 02:25 PM |
no bushes on my MK either
ch1ll1
| posted on 9/10/06 at 02:31 PM |
hard mounted did for me with no problems
mistergrumpy
| posted on 9/10/06 at 02:44 PM |
Right then. I think I've wasted a day trawling round the shops for ideas then. So hard mount it is then. Job for tomorrow as I seem to have
hurt my back carrying the engine around No matter.
| posted on 9/10/06 at 02:57 PM |
you do get a bit of humming if any panels are loose, but mine is solid too and no probs yet.
mistergrumpy
| posted on 9/10/06 at 03:05 PM |
So if I hum whilst driving, then problem should disappear. Cool.
| posted on 9/10/06 at 03:58 PM |
I've bolted mine into a cradle which in turn bolts into the chassis, I haven't heard of anyone having problems yet so I'm not going to
use bushes.
mistergrumpy
| posted on 9/10/06 at 04:37 PM |
Ah yes. I already have that picture saved for reference. Ta for that.
As a side thing. How high can I mount th'engine above top rail so as to keep it all under the bonnet?
[Edited on 9/10/06 by mistergrumpy]
| posted on 9/10/06 at 06:24 PM |
That's the engine with the standard airbox on, it's not like that now. You need to get the sump cut so you can lower it in the chassis,
Chris Gamlin's uncle did mine and a few others. I've cut and shut the airbox for now so it's lower but I'll still need to make a
hole in the bonnet if I keep it.
mistergrumpy
| posted on 9/10/06 at 06:57 PM |
Yeah spoke to Chris already ref sump. I don't wanna remove it yet though as the engines still sat on it. I want to try and avoid the engine
poking up out of the bonnet if I can as I am a bit worried about water getting in the intake and hydr locking the engine. I've seen this on cars
a couple of times and it just stuffs them completely. Am I worrying about nowt here? Mind, I could just put a covered bulge type affair on I suppose.
| posted on 9/10/06 at 08:29 PM |
not a problem unless you're in a total rainstorm - damp intake air will have no ill effect, after all some turbo'd engines use water to
cool the charge, and water is a byproduct of combustion anyway.
Chris' uncle did my sump too. I'll have a measure up sometime soon and let you know where it all sits.
mistergrumpy
| posted on 9/10/06 at 10:26 PM |
Yeah that'd be really great. Thanks Joel.
mackei23b
| posted on 23/10/06 at 08:00 AM |
Hi there
There are a couple of pics in my archive of the cradle (Home Made) and of the engine in the car.
All moutings are solid.
Hope this helps
Ian
mistergrumpy
| posted on 23/10/06 at 12:20 PM |
Nice job on that cradle mate. Do you expect the engine to poke through the bonnet at all? Mind, the Indy has a bonnet scoop anyway doesn't it?
mackei23b
| posted on 26/10/06 at 01:32 PM |
Hi there
Mines solid mounted on a home made crade, another pic is in my archive.
Ian
mistergrumpy
| posted on 26/10/06 at 04:50 PM |
Good picture ta. Quite a tilt on the engine, I hadn't thought about doing that. Was wondering how to get the exhaust and oil filter to clear
the side. Cheers.
| posted on 26/10/06 at 05:05 PM |
you want the sump line level i believe, hence the cylinders lent at the same angle as the bike.
mistergrumpy
| posted on 26/10/06 at 05:29 PM |
Yeah I thought that would be the case. I've just been propping it with wood kinda either side of the sump lobe and the engine didn't seem
tilted so much? Gonna look back through my photos of all your engines now. This would be easier with a winch or summat I guess.
| posted on 26/10/06 at 05:56 PM |
well, with mine i sat it on a block of wood, measured how far it was vertically from the bottom of the chopped sump to the two mounts over the
gearbox, welded brackets to the chassis to put the sump 1" below the bottom, and then just pivoted it on these mounts whilst i plotted the rest.
You can use a jack to adjust it to level and then weld everything else in. Dead easy Complete fluke the bonnet still fitted mind you
Bob C
| posted on 26/10/06 at 06:20 PM |
I mounted mine on rubber - no cradle, (pics on my photo archive). Now I've driven it 200yds I must say it's quite civilised in having no
vibration to speak of! There seemed no point in not rubber mounting it - it was easier than making a cradle!
Bob
mistergrumpy
| posted on 26/10/06 at 08:36 PM |
Plenty of rubber in there Bob! Nice dash pictures by the way. Did you buy it in a kit form or are did you just repair one?
| posted on 26/10/06 at 09:10 PM |
Bob
Not sure if ive musunderstood you, but having a cradle and using rubber mounts are not mutually exclusive, you could have both, either or neither.
I have just use a pair of spars rather than a cradle, and hardmounted it.
Must say yours looks very tidy
[Edited on 26/10/06 by JoelP]
