Toady1
| posted on 23/10/06 at 10:16 AM |
pics of 954 blade engine monuts
Hi, has anyone got any pics of the above in their kit car (pref mk indy)? need to plan mine!
alfasudsprint
| posted on 24/10/06 at 08:36 PM |
I am in process of making mine, its a 954 Blade in a book Locost, plus 1 inch on height of scuttle. Have pics on camera, will download tomorrow and
post if u like. I am going for the Westfield X shape cradle, with U brackets welded to chassis, so its an unbolt, lift out job, very easy, and gives
additional engine bay rigidity.
Tim
scutter
| posted on 24/10/06 at 09:27 PM |
Why not call MK, think it's only about £100 for a cradle designed for the job.
ATB Dan.
alfasudsprint
| posted on 25/10/06 at 06:41 PM |
Generally bits available are for older model engines, so take care. had same with exhaust and sump baffle.
Tim
ps will post later.
alfasudsprint
| posted on 25/10/06 at 08:32 PM |
These 2 pics show partially completed, missing 1 leg of X, plus detail of fixing, I will weld on a tube vertically to sq. tube, then bolt thro'
brkt. Will add two hanging angles for g/box side mount.
Underneath, I will use frame of sump guard to add connects to lower mount gearbox side with threaded studding.
Tim
[Edited on 25/10/06 by alfasudsprint]
alfasudsprint
| posted on 25/10/06 at 08:34 PM |
here
alfasudsprint
| posted on 25/10/06 at 08:35 PM |
and here, if u want more just ask
Toady1
| posted on 26/10/06 at 11:29 AM |
thanks for that. Re you bolting one on the bottom whete the gbox is? where the original mount on the bike is?
scutter - mk only do one for the 893 blade, im thinking of buying hat one tho and adapting it.
alfasudsprint
| posted on 26/10/06 at 12:29 PM |
Actually there are 3 points down g/box side to fix, the middle one is ~25mm dia so no good, there is another above and another below, both 12mm dia I
think, which I will use withn threaded studding.
