Wadders
posted on 30/5/03 at 05:40 PM |
orrible nasty noises
Put the back of my car on axle stands today to check that the speedo sensor was working. With the engine in gear and on tickover, there are some
really nasty mechanical 'clunking' noises which seem to eminate from the propshaft (but its hard to tell), as soon as i press the throttle
and revs rise above 1500rpm the noise stops. Iv'e checked all the bolts etc, but can find nothing wrong.
Any idea's anyone?
TIA
Alan W
theconrodkid
posted on 30/5/03 at 06:22 PM |
probly a bit of play in the diff as there is no load,its nowt to wory bout
who cares who wins
pass the pork pies
ChrisGamlin
posted on 30/5/03 at 06:32 PM |
Most likely just the diff and prop clanging around because there is no load on them as the wheels are up in the air. Probably nothing to worry about
unless it does it when you are driving too, the drive train is generally pretty noisy on a BEC at the best of times!
Chris
ChrisGamlin
posted on 30/5/03 at 06:33 PM |
Doh, where did that reply sneak up from !
Chris
Wadders
posted on 30/5/03 at 07:25 PM |
Thanks for the reasuring posts fella's, iv'e not had chance to drive it yet, except for about 20' on my drive in first gear, but by
the sounds of it i'm worrying over nowt.
iv'e got next week off work, and am hoping to finish the thing,so hopefully an ever so slightly illegal blast is on the cards.
Al.
i]Originally posted by ChrisGamlin
Chris
GJ Warren
posted on 30/5/03 at 09:29 PM |
Most bike boxes have around 30 degrees of play, it originates from the dog clutch engagement desin that lets you shift without a clutch. Under no load
the box will constantly be loading and unloading the prop as the wheels accelerate immediatley dont worry it should pass once the wheels are loaded
