nitram38
| posted on 14/11/06 at 02:06 PM |
R1 Sump Baffle possible Group Buy?
Never done this before, but I have a local CNC firm who will make sump baffles for the R1 04-05 model.
I am trying to gauge interest in a group buy.
They currently cost £75 to buy, but depending on numbers, I may be able to buy and deliver for around £30 each if I order 10.
Most of the cost goes into the cnc programming so the baffle cost should be cheaper if I can get enough people interested.
Regards Martin
Hammerhead
| posted on 14/11/06 at 02:09 PM |
Hi Martin,
I am intrigued by your new project!
I saw F1/2 at donington and was very impressed. I am making my own bodywork for my Indy, so seeing someones finished project was inspiring.
Do you care to share details of your new project? I would love to see a build diary, if you are able.
Cheers.
Steven.
nitram38
| posted on 14/11/06 at 02:18 PM |
I have already bought a £75 baffle
I just thought I might be able to save some locosters some money!
My next project will be similar to the atom in that it will be a tubular chassis with minimum body panels and low weight.
The main difference will be R1 power.
I can't build the new project until the F1/2 is sold off, because I only have a single garage.
Any offers!!!!!!!!
My brother works with someone who can get carbon fibre panels made, so hopefully my new project will have lighter panels!
I am hoping for a car around 400kg and 0-60 of 3-4 seconds.
I will start posting photo's once I make room!
[Edited on 14/11/2006 by nitram38]
andyd
| posted on 14/11/06 at 03:24 PM |
I'd agree with Mark... draw it up (even in MS Paint) and post it on here asking for someone to draw it up as a CAD model.
I'd offer to do it but I'm a bit snowed under with my own CAD modelling at the moment.
I'm sure there'll be someone that is capable and has the time to do it.
[Edited on 14/11/2006 by andyd]
cossey
| posted on 14/11/06 at 03:35 PM |
if you give me some photos with dimensions etc ill draw it up on solidworks. i need one for my 06 r1
nitram38
| posted on 15/11/06 at 01:54 PM |
It needs to be spot on or it will not fit!
If I had to take measurements then I would input it into solidworks myself, but I think it is better to give one man the job of doing the whole
thing. I will then own a copy of the cnc program for further use.
[Edited on 15/11/2006 by nitram38]
tks
| posted on 15/11/06 at 03:49 PM |
mhh
is there any reason wy a laser cant do it?
out of 5mm ally sheet?? or stainless??
the cost would be allot lower then cnc.
cnc is for 3D parts.. as far as i know that plate is a 2D component!
i gues my pinion (look reverse thread) has more circumstance(loop distance) than the baffle plate and it was 24euro in steel and weight 0,7Kg..
Tks
[Edited on 15/11/06 by tks]
G.Man
| posted on 15/11/06 at 04:37 PM |
you can cut those with a waterjet cutter...
Opinions are like backsides..
ChrisGamlin
| posted on 15/11/06 at 09:08 PM |
quote: Originally posted by nitram38
  R1 Baffle Installed
Very similar but unfortunately not the same as the earlier engine, otherwise Paul (progers) has some very nice baffles for about £35 IIRC.
I wouldnt be too concerned about the differences in the sump as regards to surge though!
