<<  1    2  >>
Author: Subject: Busa oil capacity
iiyama
posted on 21/11/06 at 09:40 PM Reply With Quote
Busa oil capacity
As Topic really. Need to know the capacity of a dry sump tank for a Hayabusa.
Ta!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
DIY Si
posted on 21/11/06 at 09:42 PM Reply With Quote
Depends how big the tanks is you've ordered! Or do you need to know the size of a standard sump so you can order a tank?
Sun Tzu, The Art of War
iiyama
posted on 21/11/06 at 09:43 PM Reply With Quote
Yup!
Im a bit green here, but I guess the tank will be the same capacity as the sump?
In which case whats the capacity??
[Edited on 21/11/06 by iiyama]
DIY Si
posted on 21/11/06 at 10:15 PM Reply With Quote
Absolutely no idea! Just thought it'd help the others!
DIY Si
posted on 21/11/06 at 10:26 PM Reply With Quote
Google says, wet sump capacity of 3.5l. I'd go over this for a dry sump tank though, to maybe 4.5 to be on the safe side. It can't hurt to have a bigger reservoir of oil.
rjbrookes
posted on 22/11/06 at 12:57 AM Reply With Quote
my zx12 is not far off 6-7 litres (i think) i have to buy 2 4 litre oil cans ......cant remeber the size of the tank, but its not small...
russ
iiyama
posted on 22/11/06 at 07:22 AM Reply With Quote
5L be big enough then ya reckon??
G.Man
posted on 22/11/06 at 07:51 AM Reply With Quote
No I reckon more...
bank on 6-7 litres..
Opinions are like backsides..
ChrisGamlin
posted on 22/11/06 at 05:59 PM Reply With Quote
Agreed, you want 6-7L in there overall I reckon, pretty sure that's what my mate's dry sump Busa has.
iiyama
posted on 22/11/06 at 07:02 PM Reply With Quote
K Guys, thanks for the info. Ill go for a 7L tank then.
iiyama
posted on 31/1/07 at 03:10 PM Reply With Quote
Just to ressurect this.....
Have confirmed that the Busa's oil capacity is 3.5L. Obviously there will be oil in the line that feeds the pump, the pump itself and in the billet sump. So if I have a 5l tank would I be correct to assume at least 1 litre in the rest of the system?
Space is a little limited hence the question! The 5 litre tank is 6" in diameter, the 7L tank is 8 1/4", although both are the same height.
The Pace site says that there 5" tank is ideal for BECs, although that only holds 3.12L of oil
Ian
G.Man
posted on 31/1/07 at 03:18 PM Reply With Quote
Ignore the BUSA's oil capacity, as you no longer have the BUSA sump... The billet sump will hold about 1l at any one time...
The oil should come to just above the seperator in the tank with the oil lines and oil cooler full of oil...
Fill the tank above the seperator about an inch, spin the engine without plugs and keep topping up to that same level until oil spits back into the tank from the return line..
A 5l tank will only have 2.5-3l of oil in it the rest depends on your hose lengths and oil cooler capacity..
Think I have the 7l tank on mine...
Total oil is about 6l
iiyama
posted on 31/1/07 at 03:21 PM Reply With Quote
SO they give the total capacity of the tank, not the oil capacity then?
G.Man
posted on 31/1/07 at 03:34 PM Reply With Quote
work it out...
(Diameter of the tank in cm/2) squared x pi x length of tank is the capacity in CC's
For a 10 inch tank length thats about 3.5 ltrs on the 5 inch diameter tank...
That may be the useable capacity or the total, I dunno how long your tank is
Having just looked at Pace's site, I would say the tank is quoted by its useable capacity..
The 5 inch looks about right half full, 3.142 litres.
And I think mine is the 5L but cant say for sure...
[Edited on 31/1/07 by G.Man]
iiyama
posted on 31/1/07 at 03:40 PM Reply With Quote
So if they recommend the 3.12L for BECs, Why go for one holding twice the capacity?
Not questioning your answers as such, I just need to get it straight in my own mind! I like to know the hows, and the whys and the wherefors!!!
G.Man
posted on 31/1/07 at 03:47 PM Reply With Quote
Because the value of protecting against oil loss outweighs the weight penalty..
And my pace tank initially leaked :eek:
More oil means slightly longer duration between changes as well...
iiyama
posted on 31/1/07 at 03:48 PM Reply With Quote
Fair enough!!!
bike_power
posted on 31/1/07 at 08:56 PM Reply With Quote
I would talk to Karl at Extreme Engines, to some degree the design of the tank is more important than the size of it.
The only time the size will be critical is when you know how much oil the engine will hold on a long, fast corner- you can find that the oil stays up in the engine rather than dropping down to the sump where it can return to the tank. Every engine will be different and the tank needs to hold sufficient to cope with this. This can easily be 3 or 4 litres or more.
You need to know what's worked already, fitting an over large tank will cost you money in oil and take up valuable space in the car as well as adding weight, weight that you (like me !) have probably spent a lot of money getting rid of.
I know Karls system works really well, have seen data logs of oil pressure in much faster cars than se7ens on slicks using his system and oil pressure is rock solid even at high g.
[Edited on 31/1/07 by bike_power]
iiyama
posted on 31/1/07 at 09:24 PM Reply With Quote
Think the extreme system is based around the Pace setup.
Ive gone for a 5L tank due to space. I personally think that a 7L tank is a little extreme, (no pun intended!).
As for setup Ill probably go for the Hayabusa Central dry sump due to the fact it uses aeroquip hoses rather then hose clips like Pace use, and they also supply the water pump in the price.
G.Man
posted on 31/1/07 at 09:32 PM Reply With Quote
My Pace uses Aeroquip?
only the 2 short scavenge pipes use hose clips, and they are low pressure and will stay on without the hose clips (I couldnt get the damn pipe off when I changed my sump, had to unbolt the union)
Water pump is useful to have, but looking at it, I doubt it will flow enough water.. mine is the bosch pump and I have switched that to the davies craig now as the water was boiling in the block!
G.Man
posted on 31/1/07 at 09:37 PM Reply With Quote
oh and the aeroquip fittings are the most expensive part of the instalation...
bear that in mind if you need extra over the pace system...
iiyama
posted on 31/1/07 at 09:40 PM Reply With Quote
Aeroquips shouldnt be to bad as I have a man on the inside!!!
G.Man
posted on 31/1/07 at 10:07 PM Reply With Quote
cool, but bear in mind what I said about the water pump...
The davies craig ones are proven to work well
I would hazard a guess thats what bike_power is uisng as well
iiyama
posted on 31/1/07 at 10:33 PM Reply With Quote
Not too sure what HC supply as a water pump, but the whole dry system comes in at under 900 sovs. Thats a whole lot cheaper then Pace or TTS, so even if I need to upgrade the pump im still quids in.
Fortunatly the same guy thats gonna supply me the aeroquips can supply Davis craig pumps too. In fact thats what was fitted to my RX-7!
iiyama
posted on 2/2/07 at 03:04 PM Reply With Quote
OK, sump tank showed today. Glad I went for a 5l, no way a 7 would have fitted. Actually wondering if I should have gone smaller!!!!
Only place ive got a space is at in front of the radiator. This places it at the other end of the engine from where the oil pump will be. Is this going to cause problems???
<<  1    2  >>
