GavBurns
posted on 25/11/06 at 10:26 PM |
Clutch cable help
Can anybody tell me what the best clutch pedal to cable link is? I've made a metal bracket which bolts to the bottom of the pedal and the clutch
cable nipple goes through it, but the last time out at cadwell the nipple pulled through. What should I use and where do I get it?
Gav
posted on 25/11/06 at 10:47 PM |
Ive used a Cortina Mk3 cable as it has a nice eye on one end that i just made a little bush for that allowes it to spin freely when bolted to the
pedal.
At the blade end, ive turned my clutch lever 180 degrees and re welded it back on, then tacked a solderless nipple into the hole where it normlly
ends, then just cut the end of the cable to length and tighten the bolt up.
Suppose it may cause the same problem you have now, but atleast its more accessable.
shortie
posted on 26/11/06 at 12:47 AM |
You can buy a ready made one from MNR, perfect for the job.
Rich.
Dusty
posted on 26/11/06 at 01:11 AM |
Escort Mk 2 from Quinton Hazel
Whoops, sorry thats a bit wide.
[Edited on 26/11/06 by Dusty]
Gav
posted on 26/11/06 at 10:50 AM |
which seems to be the exact same one as my cortina one!
GavBurns
posted on 26/11/06 at 04:06 PM |
Thank you for your help I have managed to get a link from a bike breakers.
