Winston Todge
posted on 6/12/06 at 05:36 PM |
Welding R1 exhaust can...
I've got a Titanium R1 exhaust can, the one with the small CAT in it...
I need to weld a 90 degree bend on the end and a reducer to fit on the end of my manifold.
I have seen a few people that have welded these and was curious if they had to get special rods to weld the titanium? I'm not sure if both ends
are titanium alloys or not?
Also where can I get some rolled end 90 degree stainless bends?
Thanks,
Chris.
chockymonster
posted on 6/12/06 at 05:42 PM |
MNR
DIY Si
posted on 6/12/06 at 05:48 PM |
Aren't the end caps ally or stainless?
Sun Tzu, The Art of War
Andy W
posted on 6/12/06 at 05:54 PM |
Don't forget you'll need a rolled end for S.V.A. If you're trying to weld stainless tube to adapt the inlet it will probably just
crack as it cools. You might get the bend to weld to the outlet if you're lucky. I had a go with stainless rods, titanium and mild steel and
purging the can but it still cracked as it cooled.
Andy W
posted on 6/12/06 at 06:42 PM |
Yamaha did a proper job on their titanium cans
Bob C
posted on 6/12/06 at 07:27 PM |
on mine:
the outside end caps are some kind of ally alloy.
The inside end cap & short pipe on the exhaust end are some kind of stainless.
I cut off the outer on the exhaust end & welded on a stainless 90degree bend. For the radiused end I welded on a stainless ring of 6mm diam
bar.
looks OK & SVA friendly.
I'll post a pic in a wee while
Bob
PS it's true, there IS plenty of titanium around on these - input pipe & (I think) outer cover. Spent several minutes with the grinder
showing folk the lovely white sparks!
[Edited on 6/12/06 by Bob C]
Bob C
posted on 6/12/06 at 08:04 PM |
one photo....
zetec7
posted on 7/12/06 at 12:57 AM |
Not wanting to hijack this thread, but I, too, have a Yamaha R-1 can (identical to the one in the photo) for my Zetec- engined Locost. Does anyone
know of a link to information about the catalytic converters in these cans? I've found vague references to it, but nothing concrete enough to,
asy, satisfy local inspectors that there IS a 'cat on my car...
http://www.freewebs.com/zetec7/
907
posted on 7/12/06 at 06:52 PM |
Hi
I'm afraid Ti only welds to Ti, using Ti filler wire.
Sorry if that's bad news to anyone.
Paul G
Wadders
posted on 7/12/06 at 06:59 PM |
98-99 R1 Carbon cans are ally under the carbon cover, well mine was anyhow.
Originally posted by CaLviNx
Hi
you will most likely find that your titanium can is just a cover and the rest of the can is mild steel.
If you drill out the rivets on the end cap and take it off you might see if its a mild steel can underneath like my R1 can is under its carbon fibre
cover,
[Edited on 7/12/06 by Wadders]
ChrisGamlin
posted on 7/12/06 at 08:16 PM |
Yep the carbon sleeved cans are all ally, the blue anodised looking ones are the ones with ti bits inside, but Im not sure if they vary from year to
year with regards to ti in/out/both.
As to Zetec7's question, there are cats in the later titanium cans (not sure which year) but they are very open / free flowing and very small in
comparison to a car catalyst. They don't seem sufficient to get a bike engine through the (more stringent than bike level) SVA / MOT emissions
tests for a cat equipped car, so there's very little chance it will be any better on a Zetec unfortunately.
zetec7
posted on 8/12/06 at 03:29 AM |
Oh well...we don't have emissions testing here, but if I'm asked about a 'cat, at least I can say there IS one there...
