Bitten hero
| posted on 7/12/06 at 10:00 PM |
Electric reverse again-help please
Hi all,
I am gonna have a starter reverse on the furore f1 and am looking for a donnor for the ring gear, i was told that a small auto is the way to go one
using the plate with the ring gear on( not to heavy then) please can any body give me a clue to the right sort donnor?????? please
cheers gary
nitram38
| posted on 7/12/06 at 10:44 PM |
I have bought mine from Jon lee at www.lynxae.co.uk
At £350 quid it is definitely not locost!
But you get a small geared starter which throws out the starter cog and a machined cog that replaces yor standard bike engine output.
You will need to fabricate your own mounting bracket for that aswell!
I am still waiting for the gear though, as he said that the one he had was damaged.
It is a lot lighter than a standard starter and uses less current to turn, but has the same torque as the original. Used on race cars to save the
normally smaller battery.
The closest I have seen to the starter is the catering van ford crossflow or a jag xk8 one. Martin
  Reverse starter
[Edited on 7/12/2006 by nitram38]
Bitten hero
| posted on 7/12/06 at 10:55 PM |
hi martin,
cheers for the reply but im looking for a auto flywheel/starter ring gear( ie a plate with ring gear ) that i can adapt to fit the taggart diff and
the fit a starter that possibly could be a brise geared starter to drive it.just looking for some ideas for the car and make to then go have a look
for them!!!
nitram38
| posted on 7/12/06 at 11:03 PM |
Are you going for chain or prop drive?
Found a similar starter here
EBAY LINK
OR THIS
Jon Ison
| posted on 8/12/06 at 07:11 AM |
Have a look at the Pell gennisis evo build diary site, they use something like what you are looking for, maybe get tips, inspiration on there.
here
[Edited on 8/12/06 by Jon Ison]
| posted on 8/12/06 at 04:02 PM |
Or come across to the dark side on the Se7en list... The Pell Genesis bloke (Adrian Moore) posts there, so you might be able to grill him a little bit
Also the Yahoo BEC list also has a fair few people on it who have built reverse mechs for racing BEC cars in the 750MC RGB races.
Ben
tks
| posted on 8/12/06 at 04:28 PM |
look at my topic...
it contains the cad drawing to laser one up...
i used the bendix of a valeo part number.
its was pure luck that it works fine with that bendix, sow i just tigged the bendix to my starter. (only the pinion offcourse)..
Tks
Bitten hero
| posted on 8/12/06 at 09:51 PM |
Hi all,
Martin its gonna be chain drive and as im using that wonderful tpe diff unit im going to use the brake disc drive to fit a plate with ringgear
affixed and then use a starter to drive whole lot so i need the smallest ring gear and plate that i can get away with. Thanks for all your help and i
just need to work out where to look for tks topic????
tks
| posted on 10/12/06 at 03:30 PM |
here it is...
mhhh
LINK
need to post the valeo part number...
Tks
