Alistair
| posted on 22/6/03 at 05:05 PM |
ZX9 electrical problems
got a ZX9R C engine yesterday and am trying to get it running before the warranty runs out. I need to get an oil filter and some oil before I run it,
but was trying to make sure it turned over and wasn't seized up.
When the starter button on the switch gear is pressed the fuel pump starts to work but the starter dosn't. When I short the terminals accross
the solenoid it works.
Can anyone suggest why it won't work from the switch?
Brooky
| posted on 22/6/03 at 05:36 PM |
A lot of bike engines have anti theft devices built into the ignition switch.
You may have to earth one or two of the wires coming from the ecu, do a search in the forums and see what there is.
Wadders
| posted on 22/6/03 at 05:42 PM |
If your using the standard bike loom it could be either the sidestand switch or because the engine is in gear.
If your stuck i'll dig out the manual and suss the wire colours out for you.
let me know.
Wadders
i]Originally posted by Alistair
Alistair
| posted on 22/6/03 at 09:25 PM |
Wadders
engine is in neutral. I don't know about the side stand switch. what does the plug look like that clips onto it? I have a plug which a
don't know where to put. It is black and has two terminals. It is shaped similarily to the plug that connects from the loom to the fuel pump.
could this be it?
Am I correct in the assumption that all the plugs are slightly different in shape and therefore cannot be wrongly plugged together, only to the
corresponding plug.
Also, how many pipes go to the radiator? I havn't got one yet but figure I won't need it just to check the engine runs for a few seconds.
There are the two big water pipes, but also smaller ones such as the ones that come out from where the oil filter attatches. One goes to the water
pump, where does the other go.
Bought the engine as a 'good runner' and got a box of bits
Any help is greatly appreciated
Wadders
| posted on 22/6/03 at 10:13 PM |
Sorry,i'm not sure about the shape of the sidestand switch plug, but the wires are black/yellow and green/white, they will need to be joined for
the starter to turn over. For the engine to actually fire up , you need to take a live feed through a 100ohm resistor to the grey wire coming out of
the ecu (unless you have the bikes ignition barrel and key).
The spare 1/2" cooling pipe from the oil filter housing 'Tees' into the top rad hose, you will also need an expansion tank,
connected to the rad & thermostat housing (hidden under carbs). Water drains from the expansion tank back into the system via a hose
'Teed' into bottom rad hose.
Hope this helps
Wadders.
Wadders
could this be it?
corresponding plug.
Alistair
| posted on 23/6/03 at 06:21 AM |
I have the ignition barrel so that is not a problem. I will, however, be removing this once the engine is in the car so the info about the resistor is
appreciated. Getting an oil filter today so will try and get the engine running.
Should be able to sort the plumbing out as well, cheers.
MK9R
| posted on 23/6/03 at 07:11 AM |
Short the clutch switch out aswell, yuo have all angles covered then.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Jasper
| posted on 23/6/03 at 09:33 AM |
To cut out all anti starting switches, just earth the black and green wire coming out of the ECU.
Alistair
| posted on 23/6/03 at 07:49 PM |
shorted out the stand switch and nothing happend.
shorted out the clutch switch even though the light on the clocks said it was in neutral and it worked. (thanks MK9R)
1/2 a pint of petrol later and it fired up!
didn't want to short out any wires going to the ecu as I was worried that I would brake it but thanks jasper for the advice
any ideas why the light on the clocks shows neutral but it still wont crank over without the clutch switch being shorted? Could it be a dodgy switch
on the gear box?
MK9R
| posted on 24/6/03 at 08:37 AM |
My suzuki GSXR would not let you turnover the starter motor unless the clutch was depressed, even if it was in neutral. Safety i suppose
Have a gander on my site, i have a section on getting the engine running.
[Edited on 24/6/03 by MK9R]
Cheers Austen
RGB car number 9
www.trackace.co.uk
