Author: Subject: Fireblade redline
loafersmate
posted on 16/7/03 at 07:17 AM Reply With Quote
Fireblade redline
I've got a 94' fireblade engine and dials from what I was told was a fireblade (they fit the loom and are honda). The query I have is what should the redline be? The clocks say the red starts at 14,000 and the limiter comes in at about this point. I've seen the clocks on a blokes blade at work and his red starts at 11,500!!!.....I may have the wrong clocks!
Ben
ChrisGamlin
posted on 16/7/03 at 09:53 AM Reply With Quote
Limiter kicks in at 11750 on the blade, red line starts at 11,000 on my blade clocks (99 RRX)
Sounds like you might have CBR600 clocks.
Chris
loafersmate
posted on 16/7/03 at 10:17 AM Reply With Quote
My limiter doesn't come in till 14,000 ish! That must be the wrong ECU then too?? runs good though?!
Ben
ChrisGamlin
posted on 16/7/03 at 11:02 AM Reply With Quote
If the clocks are wrong though, you are probably getting an incorrect reading of the revs. I doubt very much whether a stock blade engine would go to 14k without going pop, and if it did, dont try it again cos it will!
Chris
StuartA
posted on 16/7/03 at 02:38 PM Reply With Quote
Used to have a Honda Hornet 600 that redlined around 13500 rpm. That used a detuned CBR600 engine. Would think the newer CBR600s would redline around the 14 grand mark but the Fireblade is definitely lower as Chris says. I'm surprised the blade even fired with the wrong ECU.
ChrisGamlin
posted on 16/7/03 at 03:16 PM Reply With Quote
I have heard of people using the CBR600 ECU for upping the rev limit on a blade, but I wouldnt want to do it personally, and on a stock engine the power is tailing off before 11k anyway, so pointless revving it much past that.
Chris
[Edited on 16/7/03 by ChrisGamlin]
loafersmate
posted on 16/7/03 at 03:46 PM Reply With Quote
It not only fired but runs perfectly passed emissions at SVA no problem......anyone got a cbr900 ecu to swap for a cbr600 one??
Ben
