mike smith1
| posted on 15/3/07 at 10:09 AM |
Digital Gear Indicator and Small Wheel
Hi Guys,
Can you please post up pics of where you have located your digi gear indicators once you have the small steering wheel fitted dont want to fit it with
the sierra wheel and not be able to see it once we have changed to a smaller one!
Mike
nitram38
| posted on 15/3/07 at 10:19 AM |
This is going to be my dash layout. My steering wheel is 300mm dia and the switches will be within the 127mm projection exclusion zone around the
wheel.
  dash drawing
Mr Whippy
| posted on 15/3/07 at 11:34 AM |
cricky I just drilled holes all over the place whiles watching the telly!
designer
| posted on 15/3/07 at 12:16 PM |
If the steering wheel is central to the lower cut out, will you be able to see the dash?
| posted on 15/3/07 at 12:34 PM |
quote: Originally posted by mike smith1
Hi Guys,
Mike
Mike, why not just wait and fit it after SVA when you've ditched the Sierra wheel?
Phil
nitram38
| posted on 15/3/07 at 12:57 PM |
The two gauges can be seen through the wheel and I have a V2 veypor dash:
[img][/img]
mike smith1
| posted on 15/3/07 at 01:11 PM |
Hi Guys,
Mike
Phil
Could do but dont wanna do to much messing around after SVA, just wanna spend the time in the car and not working on it!
Mike
asn163
| posted on 15/3/07 at 05:35 PM |
Hi Mike, not seen you for a while. Here's. where we put ours:
  dash
May try setting it into the dash at some point.
Simon
[Edited on 15/3/07 by asn163]
