mad-butcher
| posted on 30/3/07 at 08:22 PM |
will I gain anything
While working on the wifes intercooled Pajero it suddenly dawned on me that the blade is breathing warm air.
My question is if I cut 2 holes were the white stickers are and relocate the air inlet pipes to the filter and then blank off the original intakes
will the engine work any better not that there's a problem with it
Tony
Ivan
| posted on 30/3/07 at 08:26 PM |
Yes - the cooler the air you put into the negine the more power it will make and the longer it will live - just make sure the new inlets realy are in
cooler air.
Jon Ison
| posted on 30/3/07 at 08:34 PM |
Looking at the pic a better solution would be extend the two inlets forward into the nose cone with some ducting, pick air up from in front of the
radiator ??
Shrink the pic a bit, its fell off the side of the screen.
mark chandler
| posted on 30/3/07 at 08:36 PM |
Definately will improve things, rip them rubber trumpets off and use larger tube and duct to the outside world.
I raced a v8 landrover, when pulling air from around the engine it ran much hotter and pinked, I then ducted to the outside world and it made a huge
difference.
Well worth a few hours.
Regards Mark
phelpsa
| posted on 31/3/07 at 10:35 AM |
If ducting to the front you should probably have the fuelling rechecked. More air = lean running = less power so you need to get the balance right.
