roadrunner
| posted on 12/4/07 at 08:07 PM |
Header tank
Where have you fitted yours, BEC boys.
  new header tank
I'm thinking near the front, but still within the bonnet area.
dilley
| posted on 12/4/07 at 08:09 PM |
mine is on the bulk head,
ChrisGamlin
| posted on 12/4/07 at 08:11 PM |
I'd just position it so the pipe runs are at a minimum really. One thing to make sure though is to position it so that if it ever blows a pipe
off, it doesn't direct boiling hot water anywhere near the footwell!
roadrunner
I thought ,nearer the front, for ease of plumbing.
  fitted engine
ChrisGamlin
| posted on 12/4/07 at 08:28 PM |
Yep, that's where mine is plumbed
  Top hose plumbing
DRC INDY 7
| posted on 12/4/07 at 09:06 PM |
I have one of those header tanks got mine from ebay exact same one
I am putting mine on the bulkhead/battery tray having the pinto engine means my space at the front is small
Puddle Dodgers Club
roadrunner
| posted on 12/4/07 at 09:54 PM |
Thats where i got this one, only £45.
ChrisGamlin
| posted on 13/4/07 at 11:52 AM |
Id suggest rubber mounting it because Ive had one alu tank crack at the welds where the mounts are welded to the main body, and the way the mounting
plates in the original post is welded then bent back isn't ideal to discourage that I wouldnt think.
roadrunner
| posted on 13/4/07 at 12:34 PM |
Good point Cris, i was just about to fit it.
