Author: Subject: Fireblade throttle bodies weird valve thingy
the_fbi
posted on 15/4/07 at 07:30 PM Reply With Quote
Looking at my spare 929 throttle bodies today I noticed a strange valve thingy which either actuates the throttles, or when the throttles are actuated by the cables, it varies something.
It has either vacuum pipes going into/outof it, or, I think more likely petrol pipes.
There is another FPR on the end of the fuel rail, so its not that, is it some kind of manual extra fuel regulator based on throttle movement?
Its purely mechanical not electrical so its not an ICV.
Thoughts appreciated.
ta
Chris
ReMan
posted on 15/4/07 at 07:57 PM Reply With Quote
the_fbi
posted on 15/4/07 at 08:09 PM Reply With Quote
Hm.... so how does that work then.
It either operates the throttle, or is operated by the throttle.
It can't be operated by the throttle, as that negates the idle part of its job.
So it must operate the throttle, but I'm sure the lines in/out are fuel, so how does the fuel pressure vary to initiate the idle change?
Thanks!
ReMan
posted on 15/4/07 at 08:14 PM Reply With Quote
They are water pipes, so I guess it'ds basically an automatic choke/fast idle device
the_fbi
posted on 15/4/07 at 08:30 PM Reply With Quote
Oh, thats very cool. Automatic fidle control.
andrew-theasby
posted on 15/4/07 at 09:27 PM Reply With Quote
Hope this link works
the_fbi
posted on 15/4/07 at 09:43 PM Reply With Quote
Thanks Andrew.
