skidude88
| posted on 1/5/07 at 08:35 PM |
Problems finding neutral
Anyone got any suggestions on the following :-
CBR1000FP
I can sit in the car and select between neutral and 1st no probs. Best I can describe is a thud one way and then a clicky spring the other.
I've compaired this to the engine Ive taken out (CBR1000FJ) - feels exactly the same.
If I go for a spin as soon as I come to a halt - b*ggered if she'll go into neutral.
I've tried with engine running and engine off.
The thud and the clicky sping have gone.
I've tried disconnected the shift lever and manually tugged up and down.
Tried keep pulling away and trying neutral (obviously engine on)
And rocking backwards and forwards in gear (engine off)
Suddenly it all starts to work - doesn't appear to be a sound or hint of anything locating internally back into place.
Once its in Neutral I can sit going up and down selecting N & 1 without any problem again.
The old engine I'd sometime struggle to get neutral but a couple of wiggles sorted it.
This is happening more or less evey time.
Any advice greatly appreciated for Monday!
James.
Early MK de-Dion CBR1000 FJ-FP.
| posted on 1/5/07 at 08:40 PM |
mine did that constantly, i put it down to a shady gearlink. However, i put up with it because you dont really need neutral.
| posted on 1/5/07 at 09:07 PM |
On bikes it's usually the clutch cable or the clutch dragging itself.
Just make sure the clutch is totally un-engaged when you put your foot down
russbost
| posted on 1/5/07 at 09:16 PM |
I'd agree, sounds like clutch drag.
ReMan
| posted on 1/5/07 at 09:36 PM |
Mate, it sounds a bit like
A) Normal bike gearbox. Neutral can be tricky, easier to select it just before you hit standstill and put your feet down or the car driving equivelant
if you know what I mean
B) Bit of clutch drag
C) Bit of a pig!
| posted on 1/5/07 at 11:04 PM |
C) Bit of a pig!
skidude88
| posted on 1/5/07 at 11:41 PM |
Bit more info/history
Fitted new engine - clutch had too much travel & pushed outer friction plate off
  too much clutch pedel travel
Restricted the pedel movement so the outer plate is approx half way out - (no idea what it should be)
  adjusted pedel
Swapped over,all but the inner friction plates - as old engines where in better condition.
Inner friction plate is different on cbr1000 - the inner plate on the new engine was clearly identifiable, so left that in place.
Upgraded to barnett clutch springs.
Jubal
| posted on 2/5/07 at 07:23 AM |
There's your prob maybe. The tangs on the last plate should locate into the shallow slots on the outer drum not as you've got it in the
stack. HTH.
  Clutch plate
[Edited on 2/5/07 by Jubal]
skidude88
| posted on 2/5/07 at 10:04 AM |
Sorry to be really dumb here...
All I know is the plates move out in the direction of your arrow, and falls off if its allowed any further travel
There's a chamfered edge (that your arrow is directly on)
Cheers as it would be nice to know how it should be
Jubal
| posted on 2/5/07 at 11:46 AM |
I may of course be speaking out of my behind but on my blade clutch it didn't work properly when I assembled it as yours is. I can't
really see from the photo if yours is the same but the blade outer drum has a defined "slot" where the arrow is for the outer plate to sit
in.
skidude88
| posted on 2/5/07 at 02:05 PM |
look the same layout as blade
Hi Jubal
Dunno?
Just looked the clutch up on www.ronayers.com on the microfiche for CBR1000RR 04-05 and looks the same layout as for my CBR1000
So how did you set yours up?
Jubal
| posted on 2/5/07 at 02:53 PM |
Mine's a 98 blade. Like I said, the outer drum has a definite slot for the outer plate to sit in. i.e. the outer plate's
"tangs" are not in line with all the inner plates. I presume it's to stop it rotating. I'm sure someone who knows what they
are doing will comment later when work kicks out.
skidude88
| posted on 2/5/07 at 03:28 PM |
Ah! - looked closer in detail at the diagrams - the "clutch outer"'s are quite different in how the plates fit in.
Jubal
| posted on 2/5/07 at 06:31 PM |
Back to the drawing board then. Sorry.
skidude88
| posted on 2/5/07 at 07:08 PM |
Been and looked at Colins clutch this evening - I see what you mean that the outer one should sit in the cut out (Colin hadn't mind!)
Yeah back to drawing board
Probably dig the clutch out again tomorrow and double check everything - Just not sure how far out the last plate should be when its pushed out
[Edited on 2/5/07 by skidude88]
ReMan
| posted on 2/5/07 at 09:34 PM |
Sorted now!
1hr and 10 mins, to get it all out, put the judder bits in and align tht top TANG correctly
Come on it won't do itself................
OX
| posted on 3/5/07 at 11:15 PM |
looks to me like you have to many plates in there
skidude88
| posted on 7/5/07 at 04:49 PM |
sorted....
N'op...... right number of plates...
The center clutch basket was bust,
You could pop the middle out of rest of the center basket casting!
Sourced a spare locally (under a BBQ) and she's now running sweet
[Edited on 7/5/07 by skidude88]
