Author: Subject: Turbo bec compression question
Wadders
posted on 13/5/07 at 06:16 PM Reply With Quote
I know its common to use two head gaskets to lower the c/r, would it not be better to use a spacer under the barrels? any thoughts for and against?
Al.
ChrisGamlin
posted on 13/5/07 at 06:24 PM Reply With Quote
Thats what they use on a lot of turbo 'busas to lower the compression, I guess you can only do it on engines that have seperate barrels though!
froggy
posted on 13/5/07 at 06:43 PM Reply With Quote
i hear good things about ferriday near stafford who do shims and various laser cut shims/gaskets for turbo cars/bikes
Wadders
posted on 13/5/07 at 06:51 PM Reply With Quote
Yes me too, and i was going to contact them, but then i thought, hang on surely a cheaper option is to space under the barrels where there's no compression to worry about.
Al.
posted on 13/5/07 at 08:38 PM Reply With Quote
As long as a double gasket will lower it enough then for sure.....
What CR are you running?
Compression ratio graph (A. Bell tuned induction book)
