Alistair
| posted on 19/8/03 at 05:23 PM |
prop shaft
Does the propshaft for a BEC require a sliding joint to allow for the slight movements of the diff and engine? If so, how have people done this or am
I as well spending my time earning some money to hand over to Mr. Keenan for one of his?
MK9R
| posted on 19/8/03 at 07:06 PM |
The MK joint only slides to adjust the length intially, you lock it up once adjusted to the correct length
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Jon Ison
| posted on 19/8/03 at 07:39 PM |
if you have a live axle then yes the prop needs a slide, irs you can get away with it.
