Author: Subject: R1 rectifier wires?
adithorp
posted on 3/7/07 at 10:22 PM Reply With Quote
R1 rectifier wires?
I ran my engine tonight and noticed that the wires (3 white) to the rectifier from the engine got warm (almost hot).
I switched off when I noticed it and checked connections but found nothing amiss. Started up again and ran it untill the fan cut in. Still warm but not getting hotter. Any ideas.
They're the original wires, I've nothing else electrical connected (lights etc) and its an 06 R1.
Adrian
[Edited on 3/7/07 by adithorp]
locoboy
posted on 4/7/07 at 06:14 AM Reply With Quote
The rectifier its self gets hot too, i would think nothing unusual with that to be honest.
Locoboy
JoaoCaldeira
posted on 4/7/07 at 03:48 PM Reply With Quote
keep the rectified in a cool place, or use a heat dissipating plate (like CPU's ones).
Joao
adithorp
posted on 4/7/07 at 05:21 PM Reply With Quote
Rectifier is mounted on a big plate with heat sink paste under it and its only just warm. Its the wires I was bothered by.
However I've been thinking about this...The engine has been started up quite a few times to satisfy customers curiosity (when they see it in the workshop). I think the battery might have lost a bit of charge and last night the alternator was just working hard to boost it back up and the wires heated up as a result. Going to see how thing go!
Adrian
TimC
posted on 8/7/07 at 08:30 AM Reply With Quote
So here's a question:
I've cut the three white wires to the length required. I guess soldering cables that get hot is a very bad plan!?
Sh*te!
Coose
posted on 8/7/07 at 08:50 AM Reply With Quote
If they get hot enough to melt the solder then you've got a real problem!
Spin 'er off Well...
posted on 8/7/07 at 08:54 AM Reply With Quote
I can't see a problem.
It shouldn't get hot enough to melt solder and the joint will conduct same as the rest of the wire. Use crimped bullets if you don't trust solder.
TimC
posted on 8/7/07 at 10:00 AM Reply With Quote
Thanks chaps!
