Adam
| posted on 17/7/07 at 03:15 PM |
Another EXUP question.....sorry!
I've done search's on this topic and my understanding is unless you don't want error codes on your dash then it's best just to
fit the motor under the dash.... is this the case?
I'm fitting a 2000 R1 motor and just wondering if i need to fit it, plus was wondering if you can hear the motor under the dash? is it
annoying?
Sorry if this has be answerd else where but i just can't find the info be gentle with me i'm still learning
Adam
[Edited on 17/7/07 by Adam]
nitram38
| posted on 17/7/07 at 03:18 PM |
Are you using the R1 clocks?
If not, then remove all together
fesycresy
| posted on 17/7/07 at 03:20 PM |
Mines under the dash.
Never ever hear it. The intake and exhaust noises drown it out.
HTH
Lyn.
stuart_g
| posted on 17/7/07 at 03:21 PM |
Why not fit the EXUP motor in the engine bay? then it won't really matter, mind you though I don't think you will hear it regardless of
where it is put.
Adam
| posted on 17/7/07 at 03:22 PM |
I plan to use the R1 clocks as there doesn't seem much options without spending a fortune.
Adam
Adam
| posted on 17/7/07 at 03:23 PM |
thanks for the reply guys.... that was bloody quick
Many thanks
Adam
nitram38
| posted on 17/7/07 at 03:26 PM |
There is supposed to be an electronic diagram somewhere on the web, but I have also heard that it does not work all that well.
adithorp
| posted on 17/7/07 at 03:27 PM |
I've just made up the widget suggested by BobC in this thread.
http://www.locostbuilders.co.uk/viewthread.php?tid=69965
Works a treat and I'm not lugging a redundant EXUP around, or I won't be when I get on the road!
Adrian
[Edited on 17/7/07 by adithorp]
nitram38
| posted on 17/7/07 at 03:28 PM |
Just found this link
zxrlocost
| posted on 17/7/07 at 04:07 PM |
Hi unless you want tto remove it altogether just leave it plugged in in the engine bay
smart51
| posted on 17/7/07 at 04:12 PM |
Mine is in the engine bay. It squeaks at key on and key off, but not loudly. You can't hear it over the noise of the engine.
Bob C
| posted on 17/7/07 at 05:15 PM |
Holy mackerel - did you see the cost of that system in nitram's link - $100 + p&p & import duty. I bet it's that same as my
circuit inside (cost about 10p). Sounds like you gave up in the end smart51 - I wonder what's the matter with yours, mine works 100% & so do
all the others I know about.... (though maybe some people aren't telling me..)
Bob
adithorp
| posted on 17/7/07 at 08:43 PM |
Think you ought to go into production, Bob!
Johneturbo
| posted on 21/2/08 at 05:18 PM |
Could someone do me a real simple diagram for this cure, as i dont have the EXUP valve with my engine kit, so i'm stuck with error code 17 on
the dash
or maybe Bob the invertor could make me one, for a small fee
cheers
john
adithorp
| posted on 21/2/08 at 08:37 PM |
Bob Exup widget
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=exup.GIF
If I can make one then anyone can!
adrian
Johneturbo
| posted on 21/2/08 at 09:08 PM |
quote: Originally posted by adithorp
Bob Exup widget
adrian
I knew you was gona say that!
do you have a pic of yours? and the parts i need from maplins, as i'm not sure what some of the symbols mean
cheers.
john
adithorp
| posted on 21/2/08 at 10:05 PM |
Neither had I.
I'll have a look tommorow. I've got a spare set of bits in case my first attempt didn't work. I'll photo them and the finished
thing if I get time.
adrian
Johneturbo
| posted on 21/2/08 at 10:37 PM |
That would be mucho great if you can.
but no worrys if you don't have time.
i'll also print of that diagram and take it to maplins, and see if i get lucky!
adithorp
| posted on 21/2/08 at 11:35 PM |
Maplin don't do a BC 847 - try a BC 547 - according the BobC almost any general purpose small signal npn transistor will do. For the capacitor I
used an aluminium electrolytic, anything from 16V upwards will do (again had to ask Bob; I didn't have a clue!) You'll also need some
strip board and a small box (matchbox sized) to put it in.
If it sounds like I know what I'm talking about with electronics...I DON'T!
adrian
Bob C
| posted on 21/2/08 at 11:41 PM |
Hope it works for you - as I said above, mine works & several others have had success, but smart51 had trouble & he's clearly no
stranger to electronics. Hey it's as small and easy as circuits get - have a go! As long as the resistors are in circuit on the inputs (and not
shorted to deck or each other) you shouldn't blow anything up!
The circuit was done because I thought the one on "bike engine transplant central" was way over complex.
If you lived a bit closer I'd give you a hand with it (would have done with Adithorp but he nailed it first time!)
Bob
Bob C
| posted on 21/2/08 at 11:49 PM |
PS here's a photo of mine. There's an extra resistor in this circuit to pretend to be some fuel in the bike tank!
The circuit is now smothered in hot melt glue to stop it oxidising (otherwise the copper of the stripboard disappears over a few years)
jimgiblett
| posted on 22/2/08 at 06:08 PM |
For the non FI models I personally wouldnt bother. The bike clock give an error code (tacho tango) but this is only when the ingnition is on and the
engine not running.
Different matter for the FI engine as it displays on the clocks all the time. In which case one of Bobs wonderful circuits dues the job.
Dont stick the mototr behind the dash get a circuit like Bobs. Then you can sell the exup unit and drink beer on the proceeds. Bob I still owe you a
couple of beers now
- Jim
Bob C
| posted on 22/2/08 at 07:44 PM |
hey Jim - it worked then!
Shame you're the other end of the country, I could just do with a couple of beers.......
Bob
adithorp
| posted on 22/2/08 at 09:52 PM |
Just don't collect all these owed beers at the same time or you'll be pissed!
adrian
adithorp
| posted on 22/2/08 at 11:12 PM |
Some pictures as promised.
Forgive the diagram Bob (and any one else that understands electronics) but converting you diagram to fit on the strip board was the tricky bit for me
so I've included it for anybody elses benefit who's as dense as me with these things!
http://i189.photobucket.com/albums/z282/adrianthorp/fury044.jpg
http://i189.photobucket.com/albums/z282/adrianthorp/fury046.jpg
http://i189.photobucket.com/albums/z282/adrianthorp/fury047.jpg
http://i189.photobucket.com/albums/z282/adrianthorp/fury045.jpg
adrian
