TimC
posted on 11/8/07 at 02:04 PM |
Odyssey PC310 and first start-up
Hi All
I'm very close to starting my engine for the first time. I've had some good advice on a first-start procedure, turning over minus sparks
and fuel to build oil pressure etc. I'm using a tiny PC310 battery which I'm told will do the day-to-day job however I'm concerned
that the lengthy cranking for 1st start might be too much. What do you think?
andybod
| posted on 11/8/07 at 02:31 PM |
i've used the oddessey 680 and when i first started i used a jump battery just to give it the extra bit of boost not needed it since
smart51
| posted on 11/8/07 at 05:01 PM |
Are you that confident that it will start first time? Get a battery charger, you will need it.
