zakeen
| posted on 22/8/07 at 07:48 PM |
Chain drive or Quaife PowerTec Gear Drive?
I'd like to build a BEC and Im doing my research into it. Ive come across the
Quaife PowerTec gear drive:
http://www.quaife.co.uk/Quaife-PowerTec-gear-drive-system
Which is priced around 975pounds.
Ive noticed some here have use a chain drive.
Whats the plus minus of each system? This Quaife looks pretty good.
Thanks for your reply.
blakep82
| posted on 22/8/07 at 07:54 PM |
reverse on the gear drive looks handy
________________________
nitram38
If you are going middy or rear engine, then chain diff is a cheaper option.
I have an xr4i 4 X4 lsd diff.
  chain diff side view
With electric reverse:
[Edited on 22/8/2007 by nitram38]
zakeen
| posted on 22/8/07 at 08:23 PM |
Hello Nitram, Thats one of the reasons why I asked. When I first did the research I saw the Quaife, then after spending a few hours reading everything
here(almost) I saw your car and asked the question. Apart from price, why is your system better?
nitram38
| posted on 22/8/07 at 08:33 PM |
I would think that is lighter (not sure) and I can change my final drive ratio by changing the rear sprocket.
Minicooper
| posted on 22/8/07 at 08:36 PM |
That Quaife box was about three grand last time I looked, I would be amazed if it was £975
adampage
posted on 23/8/07 at 07:14 AM |
Powertec website says 2490 gear drive, 1290 chain drive, and that´s probably ex-vat.
975 would be cheap!
| posted on 23/8/07 at 09:18 AM |
Which engines does the Quaife fit? I've only seen it for Hayabusa so far.
zakeen
| posted on 23/8/07 at 07:33 PM |
Yes, sorry I was wrong. He gave no link from his email to his site and I got the products mixed up with this one:
http://www.quaife.co.uk/Yamaha-R1-1000cc-6-speed-gearkit
sorry. So with the correct price I might just stay clear of it.
Minicooper
| posted on 26/8/07 at 12:11 PM |
I've seen that type of geared Quaife fitted to ZZR1100/1200 and Blackbird motors, it doesn't fit the R1 or the CBR1000RR as well I believe
there isn't enough room for the cup drive on either of those two motors as the sprocket is very close to the crankcase
