matt.c
posted on 13/9/07 at 10:36 PM |
ZX9 Cooling Pipes
A few questions.
1. Is this the right way to plumb my zx9?
2. Should the oil cooler pipe be "T"ed in to the bottom hose instead of the top hose?
3. If i use an inline temp sensor/switch for my fan, should it go in the top hose?
4. Is it ok to join rubber hoses to copper pipes with juberliy clamps? (will they seal ok?)
RAD HOSE SETUP
Many thanks locosters.
[Edited on 13/9/07 by matt.c]
mackei23b
posted on 14/9/07 at 06:33 AM |
Yes, thats what I've used, Oil cooler outlet to the top hose as it's hot water into the radiator, the bottom hose is cooled water that is
pumped back into the engine. (I didn't have the top bleed from the radiator).
Ian
[Edited on 14/9/07 by mackei23b]
MK9R
posted on 6/6/08 at 06:48 AM |
which in the inlet and which is the outlet on the oil cooler?? Or does it matter?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
