rotax78
| posted on 15/9/07 at 03:28 PM |
Malc does it again, engine runs
Just got my 05 r1 started after being sat in a box for 9 months. dropped a bit of a b***ck wiring the main switch. I had enlarged then printed the
wiring diag out to take into the garage, but it was a bit low resolution and i missread the connections, causing me to burn out the cut out relay.
Malc diagnosed it over the phone (on a Sunday night) and sent me a freeby replacement, hows that for after sales service. TOP BLOKE . A couple of
other brainteasers were a bent connector pin on the pump not making cotact, and me not orientating the lean angle switch correctly (pilock) I
wouldn't hesitate in recommending yorkshire engines, can you imagine getting that sort of help out of a breakers yard?
imp paul
| posted on 15/9/07 at 03:47 PM |
yep he is a good chap very helpful and knows his stuff also has helped my mate Paul a fair bit also
bigrich
| posted on 15/9/07 at 03:52 PM |
couldnt agree more top bloke top service, top engines.
