RickRick
| posted on 18/9/07 at 12:29 PM |
engine and dry sump
is there any way to tell if an engine will need to be fitted with a dry sump, before sticking it in a 7 style car, or is there a list anywere of
engines that can be used without dry sumping
ChrisGamlin
| posted on 18/9/07 at 12:59 PM |
There's no way of telling Im afraid although an experienced engine builder may be able to make a qualified guess given the sump design etc.
There's not even a definitive answer for each engine as some of it depends on things like the type of use (road / trackday / racing etc), with
how much grip (tyres / downforce etc), and which orientation the engine is installed.
Having said that, assuming "Normal" use of road / track driving on road legal sticky rubber (Yoko 48s / R888s etc), then there's
only a couple engines that needed dry sumping, off the top of my head, which are the the Blackbird and debatably the busa.
v8kid
| posted on 18/9/07 at 01:04 PM |
Depends on how fast you go round corners. In my TR7 the V8 had no problem with oil pressure - installed in a lower chassis with sticky tyres it
suffers from oil surge badly. Beware the cost though its not just a pump and sump you have all the pipes and reservoir not to mention exorbantly
priced fittings to boot.
| posted on 18/9/07 at 02:35 PM |
If you post up a list of engines you're considering, I'm sure we (LB members) could give you some advice.
Phil
finlay
| posted on 8/10/07 at 08:10 AM |
i m in the process of building a MNR RTIB with a bussa but can make up my mind wheather to dry sump it, i ve been speaking to different people some
say yes and some say running a sump baffle is fine
i think if you ve got the funds ie 1K quid then do it but if not go with the baffled sump and take it easy round corners lol
i will prob dry sump it once i ve got all the other things done and get it through its SVA but in the mean time i will just run a sump baffle, also
MNR advised that their bussa demonstraighter just runs a baffle
cheers
