| posted on 15/9/03 at 05:23 PM |
ZX9R Carb Problem
Thanks to you all for all the advise and help but it seems I have destroyed the rubber tip on the needle valve so they don't seal any more. New
ones only come in a kit with the seat, O ring and spring and cost £37 each Four required...
AAAAAAAAAAAARRRRRRRRRRRRGGGGGGGGGGGGGHHHHHHHHHHHHHH
tadltd
posted on 15/9/03 at 09:14 PM |
Was this after you soaked them in solvent/acetone/cleaning fluid?
Steve.
| posted on 16/9/03 at 07:40 PM |
Hmm I used cellulose thinners but didn't keep the rubber tip of the needle away from it. Also thinking the needle valve seat was pressed in
didn't count on there being a rubber O ring under it. Result: needle vavles not cutting off the fuel when the float level is correct and
pumping up through the spray tube and into the venturi.
It's painful man I tell ya!
