Wadders
posted on 20/9/03 at 01:04 PM |
ZX9R regulator problem
Hi all
My battery was getting 18v pushed through it, so i assumed the regulator/rectifier had packed in. have fitted a brand new pattern one today, and the
battery is still showing 18v at 2000rpm.
The manual shows two lives coming from the regulator, a white wire which supplies the charging and a brown wire which supplies the fuse box. Both old
and new units are showing 18v on the white and 0v on the brown. Have i bought a duff unit or am i missing something?
The alternator checks out as being Ok.
TIA
Al.
[Edited on 20/9/03 by Wadders]
theconrodkid
posted on 20/9/03 at 01:30 PM |
if u got 0 volts at the fuse box then poss bad fuse?fuses supply things not take power from things,brown in car circles is earth?
who cares who wins
pass the pork pies
Wadders
posted on 20/9/03 at 01:35 PM |
Nah, the brown is the main feed to the fuse box, i.e before the fuses.
i]Originally posted by theconrodkid
theconrodkid
posted on 20/9/03 at 02:04 PM |
better have a word on bec list,in car circles reg varies magnetic field in alternator field windings ie more volts to field stronger field more volts
out 13.5-14 v would be about right
who cares who wins
pass the pork pies
theconrodkid
posted on 20/9/03 at 02:05 PM |
checked the earth?????
who cares who wins
pass the pork pies
highspeeddirt
posted on 20/9/03 at 05:39 PM |
The brown wire going to the reg needs a 12v ign fed live. If you look at the bike wiring diagram the white wire supplies power to the ignition switch
then, when on, the brown wire feeds the fuse box and BACK to the regulator. I assume the regulator uses this to check what voltage is requied by the
battery.
Wadders
posted on 20/9/03 at 05:42 PM |
Sussed it! and infact you were on the right lines, the brown live wire didn't actually power anything, i'd powered everything up from the
white one, somehow this affected the regulator output, as soon as i put the brown into the ignition circuit, everything worked ok.
So the car has been wired wrong from day one, and there was nothing wrong with the original rectifier. Bugger
£75 rectifier going cheap anyone?
Thanx Conrod, fresh pair of eyes and all that!
theconrodkid
checked the earth????? [/quote
Wadders
posted on 20/9/03 at 05:47 PM |
Sorry Steve
missed your post, due to the giddiness of fixing the thing. Yes your right, spot on diagnosis.
Al.
i]Originally posted by highspeeddirt
battery.
Steve [/quote
