Dangle_kt
| posted on 18/10/07 at 07:17 PM |
Unexpected mounts... opinions please.
Took delivery of my blade engine today, and I'm very pleased with it!
Below are the pics - the rear mount wasn't what I was expecting - is it standard?
Dangle_kt
mistergrumpy
| posted on 18/10/07 at 07:47 PM |
Its more or less the same as my ZX9 so yes I'd presume its standard
roadrunner
| posted on 18/10/07 at 07:54 PM |
You would probably remove the two flanges either end , and use a single long bolt ,or threaded bar with lock nuts.
Jon Ison
| posted on 18/10/07 at 08:18 PM |
Yup, there is another mounting the same at the bottom of the engine out of shot in the photo, I picked up on all four with two long bolts if that
makes sense, ditch the flanges as suggested.........
watsonpj
| posted on 18/10/07 at 08:42 PM |
My fury has a engine mount as Jon descibes which was supplied by fishers.
Jon Ison
| posted on 18/10/07 at 08:55 PM |
I been sussed, I wondered where I copied the idea from.........
mad-butcher
| posted on 19/10/07 at 08:35 PM |
As jon says , MK use the ones marked by red arrow as well. a word of advice the temp sensor marked in yellow has a bad habit of seizing and snapping
off when you try to remove it
