IndyJohn
posted on 30/10/07 at 03:15 PM |
headlight replacement
Hi
I am replacing the headlights and I have managed to get the wiring through the arm that the headlight bolts onto. My problem is what tool is used to
tighten the headlight ? As i cannot use a socket as the wire comes out from under the bolt and I cant use a spanner as the bolt is too deep into the
recess.
has anyone a clue of what I mean????
John
locoboy
posted on 30/10/07 at 03:17 PM |
I know EXACTLY what you mean!
I cut the arm so that it no longer had a recess and then drilled a hole in a nut cover, fed the wire through the nut cover and then put it in
place.
you can see it here
![](/galpreviews/sva3.JPG) ![sva3](/gallery/sva3.JPG) sva3
[Edited on 30/10/07 by locoboy]
Locoboy
IndyJohn
posted on 30/10/07 at 03:22 PM |
thanks for the reply
what do you mean by the nut cover?
My wires come out of the bottom of the thread that the nut goes over .
I assume that if you cut the recess down then you will be able to just get it with the spanner working at an angle?
thanks john
nludkin
posted on 30/10/07 at 03:41 PM |
You could also pad the underside of the headlamp with washers to allow for a spanner to tighten the nut (Albeit at an angle)
Would need to be VERY tight though!
stevec
posted on 30/10/07 at 03:58 PM |
I used a sparkplug socket, the type that has a hexagon on the top of it. just poke the wires through then tighten using socket and spanner.
worX
posted on 30/10/07 at 04:10 PM |
Thats a good idea Steve - If I'd heard that before I'd done mine, I would of done it that way - as it happened mine were already wired in
and I couldn't do it that way.
I cut a notch out of an old socket and used that.
Alan_Thomas
posted on 30/10/07 at 05:08 PM |
John, I sacrificed an old offset ring spanner. I ground a slot in it to allow me to slide it over the wires and it reaches up and allows me to tighten
the nut. Although the strength of the spanner is compromised I havn't managed to break it despite using enough force to really tighten the
mounting.
- Alan
IndyJohn
posted on 30/10/07 at 07:25 PM |
hi
thanks for all replies
think I will try steves first that sounds great
and Alan that sounds a great tip.
thanks all
john
IndyJohn
posted on 31/10/07 at 04:38 PM |
Hi
got the lights off and the sparkplug spanner trick works a treat BUT when you tighten it up thast blocks the hole that you then need to send the wires
down?
If you send the wires down first, you cant tighten the nut unless you have a very thin open ended spanner?
Should i just grind a spanner down?
thanks john
