Pezza
| posted on 2/11/07 at 06:11 PM |
Clutch cover (r1)
I'm replacing the clutch cover on my 5jj r1 and have a couple of questions for you chaps.
Do I use gasket sealant with the gaskets on the engine?
Does the clutch release arm go back in position just touching the spring?
(stupidly forgot to check the position before I removed it
Pez
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
mad-butcher
| posted on 2/11/07 at 06:51 PM |
I wouldn't recommend the use of any jointing compoun unless stated by yamaha, some of the oil drilling are very small. the amount of crap
i've seen on some oil pick-up filters is unbelievable
Tony
ChrisGamlin
| posted on 2/11/07 at 08:01 PM |
Agreed, the gaskets are only a few quid from the Yam dealers anyway so not worth scrimping on.
Not sure on the positioning question, quite a long time since I last re-fitted my cover.
Pezza
| posted on 4/11/07 at 01:40 PM |
cool i've got the gaskets already, was just double checking nothing else was needed.
Ben
