Author: Subject: Oil Cooler for Blade
Avoneer
posted on 15/11/07 at 12:35 AM Reply With Quote
What's the best way to connect it?
Sandwich plate? (what size?)
Pat...
Crazy Eddie
posted on 15/11/07 at 11:13 AM Reply With Quote
Hiya Pat,
I don't have an oil cooler on mine but if you check out John's website I know he fitted one: Turboblade
Hope this helps
Eddie
www.EdwardsSchoolOfMotoring.co.uk
For online shopping that earns you money : Ei42.com
progers
posted on 15/11/07 at 11:40 AM Reply With Quote
With a blade its really not necessary to connect an oil cooler if you get the water cooling correct. Its all about getting good airflow through your rad and a means for the hot air to escape away from the engine bay.
Most RGB racers do without. Andy Bates sells a very good quality Rad that will definitely solve your problems if you have issues with a micra/polo rad installation. By the time you have bought an oil takeoff plate, hoses and cooler, the more expensive water rad doesn't look such a bad deal. No external oil cooler also means less chance of failure, leaking joints etc.
Food for thought
- Paul
Avoneer
posted on 15/11/07 at 12:04 PM Reply With Quote
I'm using the standard blade rad and my water never gets over 91ish, even on track days.
My oil temp gets upto 120 though.
Pat...
paublo999
posted on 15/11/07 at 05:07 PM Reply With Quote
I had a the same scenario, good water temps and oil approaching 120 after 10 laps of Knockhill
I contacted Think Auto, they will supply a sandwich plate for between the oil filter. I went for 3/4 bsp connections and picked up an 8 row / 235 width cooler "Serck" off ebay for £25. All in all around the £70 mark with connectors etc...
All in all the car runs much better, but probably a bit over cooled at this time of year.
Paul.
Avoneer
posted on 15/11/07 at 05:58 PM Reply With Quote
Do you know what cnnectors were on the sandwich plate?
Pat...
Jon Ison
posted on 15/11/07 at 06:52 PM Reply With Quote
Dont you allready have a water to oil cooler allready fitted as std ?
ChrisGamlin
posted on 15/11/07 at 07:43 PM Reply With Quote
Hi Pat
As you know I had two other engines before the one you've got now, all were 919s and all installed identically.
The first engine oil temp used to about right although a smidge higher than ideal on very hot trackdays. The second one ran slightly cooler, verging on being a bit low on track unless it was quite warm. The last one (the one you have) ran hotter than either especially in hot weather when I had to keep an eye on it on long sessions, although the water temps for all were about the same.
The same can be said of a couple of friend's 893s, they both ran hotter than my first two engines but about the same as the last and needed a cooler. I cant really explain why, I dont know if there's a variation in tolerences on the bearings etc, but if Id kept that engine I would have probably put an oil cooler on, which I didnt need for the other two.
Chris
andrew.carwithen
posted on 15/11/07 at 07:46 PM Reply With Quote
I thought you were selling your car, anyway, Pat?
Or have you changed your mind again?
Avoneer
posted on 15/11/07 at 11:18 PM Reply With Quote
Cheers all.
Yep - it's still up for sale, but I intend to keep "tracing" it until the day it goes (just done Donnington).
I also want it to be 100% reliable when it goes ('cause I'm nice like that).
I'm already working on the replacement car that's in my drive to turn it into a track car.
Chris - do you know what sort of sandwich plate I need?
Pat...
paublo999
posted on 16/11/07 at 08:47 AM Reply With Quote
size = 3/4 bsp
two push fit connectors on to the plate, with two 90's for the cooler end.
make sure you mount the cooler in front of the radiator, seems simple but I have seen a few that are oil heaters with the air from the rad cooking the oil...
ChrisGamlin
posted on 16/11/07 at 09:31 PM Reply With Quote
Pat, might be worth giving Think Auto a call, they must have supplied quite a few by now
Dangle_kt
posted on 17/11/07 at 05:29 PM Reply With Quote
bandits run oil coolers, you could pick up one of them cheap on the bay of e I bet.
