Author: Subject: BEC bike hydraulic clutch master cylinder
Richard Quinn
posted on 24/11/07 at 12:40 PM Reply With Quote
To those who are using the original bike m/c for the clutch - How are you mounting the m/c and how are you actuating it from the pedal? I have a few ideas of my own but would like to see if there is a concensus or an option that stands out.
Thanks in advance.
Richard
pathfinder
posted on 24/11/07 at 12:54 PM Reply With Quote
I’m going to use a bike rear brake cylinder as it is easier to mount!
tks
posted on 24/11/07 at 01:01 PM Reply With Quote
yupsz this is generly done....
to operate the clutch only piston diameter is nececary, stroke is important but not deadly...
Tks
russbost
posted on 24/11/07 at 01:27 PM Reply With Quote
I weld a bracket at right angles to the frontplate of the pedal box with 2 holes to bolt into the original m/cyl mounts, cut off the end of the ali casting on the clutch m/cyl (in my case old ZX10) as it's not required & grind down the end of the car operating pushrod (in my case MR2) to the size of the bike pushrod - 4mm dia IIRC. Does the job a treat & looks neat when finished. HTH
russbost
posted on 24/11/07 at 05:16 PM Reply With Quote
Just added the pics to my photo archive if you want to see how I did it. HTH
