Author: Subject: in tank fuel pumps
stuart_g
posted on 4/12/07 at 08:45 PM Reply With Quote
in tank fuel pumps
I am thinking of fitting an R1 in tank fuel pump into my fuel tank rather than have a seperate pump mounted somewhere at the rear of the car.
Is there any particular reason people use seperate pumps rather than in tank?
[Edited on 4/12/07 by stuart_g]
twybrow
posted on 4/12/07 at 08:52 PM Reply With Quote
Mine is in the tank (from the bike). It seems to work well and is one less thing to plumb and fit somewhere in the back end. I have no idea why some people shy away from doing it...
fesycresy
posted on 4/12/07 at 09:43 PM Reply With Quote
I would say just the fabrication part. It's easier to use a standard tank and a 10mm take off to an external pump.
No need to use an internal pump for a carb'd engine - the R1 only went internal when injected.
I plasma cut my 'swirl pot' base out of 12mm ally plate to recess the pump, then TIG'd it in.
I suppose not everyone has this option.
stuart_g
posted on 4/12/07 at 11:27 PM Reply With Quote
the engine is injected and it was the in tank pump from the bike I was going to use.
I have a square sump on the bottom of the tank with the outlet coming out of one side. I was planning to use the original outlet as a draining point if I ever needed to empty the tank then cut a hole in the bottom of the sump part for the fuel pump.
Anyone see any problem with this?
The only thing I can think of is the thickness of the aluminium and fixing the pump to it.
RazMan
posted on 5/12/07 at 08:00 AM Reply With Quote
I used a Landrover jobbie - pump, swirlpot & sender all in one. Rescued attachment Land Rover Discovery 4.0L V8 fuel pump assembly.jpg
Raz
JAG
posted on 5/12/07 at 09:16 AM Reply With Quote
That's a nice looking unit - which Landrover? and how tall?
Justin
RazMan
posted on 5/12/07 at 09:37 AM Reply With Quote
Check out this thread
Raz
Bluemoon
posted on 5/12/07 at 09:59 AM Reply With Quote
RazMan, any idea of the sender hole diameter, needed in the tank? Thinking about future proofing for latter EFI install, without the need to cut a tank that has had petrol in it..
Dan
RazMan
posted on 5/12/07 at 10:12 AM Reply With Quote
Unfortunately I can't get to it without dismantling half of my car but I seem to recal that it was around 120mm diameter like an Aero cap but bigger. You need to make a fixing ring that secures it on the inside of the tank with a rubber gasket (supplied with the pump iirc)
Raz
Bluemoon
posted on 6/12/07 at 08:30 PM Reply With Quote
Thanks, might investigate this one.
Dan
