Gremlin
posted on 7/10/03 at 09:28 AM |
Bike Bits Needed?
This has probably been talked about before but had a quick look and couldn’t see anything.
I’m new to BEC and as well as been stuck between what engines;
R1
GSXR1000
ZZR1100
ZX9R
Etc
Etc
I am not sure what bits I need to get when I buy an engine?
I have been offered a zx1100 engine for 650 but needs carbs and loom is this a good engine and how expensive will it be to replace the extra
ancillaries?
EZy GreMLiN
"The only way to get rid of temptation is too give in to it..!"
Jasper
posted on 7/10/03 at 12:39 PM |
I'd forget this engine - seems a lot of money with no carbs/loom.
Things you need with the engine are:
Carbs
Looms
ECU
Fuel Pump
Coils
And if you can get them cheap/free: clocks, airfilter, clutch cable, rad, ignition with key
Gremlin
posted on 7/10/03 at 12:42 PM |
Ok forgotten about it already. Nightmare sourcing a good reasonably priced BE!
EZy GreMLiN
