Author: Subject: substitute temperature sender for R1
mad-butcher
posted on 18/12/07 at 08:28 PM Reply With Quote
I'm using the standard R1 clocks, the engine came without the temp sender, is there a substitute sender availiable within the R1 specs ie
47.5-56.8 ohm @ 80 deg c
16.5-20.5 ohm @ 115 deg c
unfortunately i'm not prepared to pay £25 for a s/h one or £45 for a new one, common sense tells me it would be cheaper to buy a seperate clock
Tony
chris_harris_
posted on 18/12/07 at 08:34 PM Reply With Quote
What year is you engine, may have one at home if its an early one.
mad-butcher
posted on 18/12/07 at 08:53 PM Reply With Quote
Chris
it's a 4xv carb
tony
