Author: Subject: Standard Exhaust
mistergrumpy
posted on 28/12/07 at 07:47 PM Reply With Quote
Standard Exhaust
I know a lot of people here use the the R1 carbon can but is there any reason I cant use the standard ZX9 titanium can if I stick a bent bit on the end. It has a cat already inside. Oh and where do I get a bent bit if I can.
posted on 28/12/07 at 08:27 PM Reply With Quote
If you're using it because it has a CAT fitted, then it won't be sufficient to get you through SVA. If you intend fitting it after SVA it will seriously restrict your engines power.
Phil
mistergrumpy
posted on 28/12/07 at 08:36 PM Reply With Quote
Well I did wonder why it wouldn't do on its own but yes I was going to use it in conjunction with a separate cat if I can get a bendy bit. See me through sva then get summat straight through. Its just that I got it with the engine and may as well use it
