Author: Subject: Yamaha R1 Gaskets
bassett
posted on 15/1/08 at 11:17 AM Reply With Quote
Yamaha R1 Gaskets
Hi, im taking the covers and sump off the R1 at the weekend can i use a liquid gasket/shaped paper gasket or should i go for the original part? if so anywhere i can get them online?
cheers
jambojeef
posted on 15/1/08 at 11:31 AM Reply With Quote
I used some fake sikaflex and its held up on ally - ally faces brilliantly countless times on clutch cover, sump, rocker box - you name it.
Just make sure it is abslutely free from oil and grease and that you dont put so much on so as to leave little 'tails' of the stuff inside ready to break off and get sucked into the oilways.
posted on 15/1/08 at 11:40 AM Reply With Quote
Yup. Make sure it's just a smear otherwise you'll ned up with loads of grot inside the engine....
posted on 15/1/08 at 11:43 AM Reply With Quote
And don't tell anyone but on the ST1100 I just left the old gasket it place, gave it (and the contact surface) a bit of a wipe with new engine oil and no leaks (yet!!)... I'd bought a clutch gasket but decided not to fit it until I was sure I'd done the clutch replacement okay. I found I'd done the clutch okay and old gasket didn't leak so I've never got round to changing it....
smart51
posted on 15/1/08 at 12:32 PM Reply With Quote
I've reused undamaged gaskets on the clutch cover and rotor cover without problems. The sump gasket is permenantly under oil so any leak will show badly.
stuart_g
posted on 15/1/08 at 03:31 PM Reply With Quote
my sump gasket split into lots of pieces. a new one is only £6 so not worth trying to use liquid gasket.
ChrisGamlin
posted on 15/1/08 at 06:11 PM Reply With Quote
Agreed, if they were £20-30 a shot and you needed to replace them every other week, then I can understand seeking an alternative, but for £6 every once in a while its just not worth it. Doing it with the original gasket pretty much guarantees an even consistent sealing surface as long as you clean the mating surfaces, and guarantees you won't get excess gloop in the engine when it squeezes together which is a serious possibility even with the most evenly/sparingly applied liquid gasket.
bassett
posted on 15/1/08 at 08:48 PM Reply With Quote
cheers everyone, think il get a proper yamaha gasket for the sump, and the rest some sort of liquid gasket depending on condition.
