Author: Subject: not sure if i should have done that!!!!
IDONTBELEIVEIT
posted on 20/1/08 at 06:27 PM Reply With Quote
hello again,is this part a serviceable part or do i have to put this one back together???does anybody know what sort of oil goes in these(viscosity) like 20w 50 or somethingcheers wayno!!!
Jon Ison
posted on 20/1/08 at 06:32 PM Reply With Quote
which part is this part ?
Don't even think about putting oil in your bike engine that is designed for use in a car engine btw.
cidersurfer
eh?
shimming solid lifters is a job for a friend...
blakep82
posted on 20/1/08 at 06:34 PM Reply With Quote
the diff you had apart earlier?
________________________
bonzoronnie
Picture please
A picture might help.
If it is not seviceable, perhaps you souldn't have pulled it appart !!??
Ronnie
IDONTBELEIVEIT
posted on 20/1/08 at 06:41 PM Reply With Quote
bonzoronnie
posted on 20/1/08 at 06:48 PM Reply With Quote
Sierra drive shafts
The CV boots are replaceable.
I dont think you can do much with the CV joint itself. Other than replace it, that is.
The CV joint requires the use of CV joint grease.
Ronnie
[Edited on 20/1/08 by bonzoronnie]
posted on 20/1/08 at 07:08 PM Reply With Quote
A boot kit will come with a pack of correct cv grease.
Its really thick and horrible and is not runny like in your picture. Its the correct cv grease you need and not oil!
Litemoth
posted on 20/1/08 at 08:30 PM Reply With Quote
If somebody's been experimenting by pouring oils and things they've had left in jars, into your joint, then it may be frigged.
The pukka stuff is a a high pressure type grease (known as Moly grease -molybdenum disulfide grease) All the lubricant manufacturers do one and a variety of synthetic ones too. They usually come in a mastic-gun size tube.
Alternatively ask your local spotty autoparts attendant for a sachet of 'CV grease'
Oh, yea, & don't put it in your mouth.
You've used that tray for something else beforehand haven't you?
[Edited on 20/1/08 by Litemoth]
robinj66
posted on 20/1/08 at 09:34 PM Reply With Quote
If it is bu66ered you might want to try these people
http://cgi.ebay.co.uk/FORD-SIERRA-SAPHIRE-SCORPIO-GRANADA-INNER-CV-JOINT_W0QQitemZ140186049659QQihZ004QQcategoryZ10372QQrdZ1QQssPageNameZWD1VQQtrksidZ p1638.m118.l1247QQcmdZViewItem
Mr Whippy
posted on 20/1/08 at 09:39 PM Reply With Quote
that's kind of gross
