chrisg
| posted on 22/1/08 at 07:14 PM |
Swirl pot
Just a quick one O bike engine experts
Would a car with an R1 (2006) need a fuel tank with a swirl pot?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
PAUL FISHER
| posted on 22/1/08 at 07:30 PM |
I would say yes Chris on the 06 r1,due to design of the fuel pump,it does not have a built in swirl pot like the injection blades,so even if you had a
baffled tank,when running low on fuel you may have fuel starvation issues.
R1 pump picture
PAUL FISHER
| posted on 22/1/08 at 07:34 PM |
Compare with the blade pump,just to add no expert just my opinion
chrisg
| posted on 22/1/08 at 07:47 PM |
More of an expert than me!
Someone in the club has asked, do you need a fuel return pipe on the tank too?
cheers
Chris
nitram38
| posted on 22/1/08 at 08:04 PM |
What if you make a cup for the tank so that the pump sits slightly below the bottom of the tank plus baffles?
chrisg
| posted on 22/1/08 at 08:20 PM |
The pump fits into the side/bottom of the tank doesn't it?
I'm not sure
[Edited on 22/1/08 by chrisg]
PAUL FISHER
| posted on 22/1/08 at 08:40 PM |
cheers
Chris
Yes Chris you need a return on that injected R1 pump,Martin Keenan does a fitting for the late R1,similar to one he did for me on the zx10 I will try
and find a picture,it fits in the base of the tank
| posted on 22/1/08 at 08:43 PM |
This picture shows the sump on the bottom of our fuel tank into which the pump fits. Not an R1 but you get the idea. The smaller hole is for the fuel
sender.
[Edited on 22-1-08 by Hellfire]
PAUL FISHER
| posted on 22/1/08 at 08:45 PM |
Here you go,it has the channel for the rubber seal
| posted on 22/1/08 at 08:53 PM |
cheers
Chris
No, you don't need a return pipe on the fuel tank itself if you're using the 2006 R1 fuel pump. The original pump has a feed and return
pipe as well as an inbuilt filter and level sensor.
Phil
Monkeybasher
| posted on 22/1/08 at 09:13 PM |
Mk2 Golf GTI fuel pump has a swirl pot.
I used it on my FI setup.
chrisg
| posted on 22/1/08 at 10:25 PM |
Thanks chaps, very useful!
Chris
rf900rush
| posted on 23/1/08 at 08:37 PM |
When converting my RF900 BEC to GSXR600 TB's and Megasquirt I used a GSXR fuel pump/regulator assembly.
I then (with help) fabricated a small tank in stainless to mount the pump, which also doubles as a swirl pot.
[Edited on 23/1/08 by rf900rush]
rf900rush
| posted on 23/1/08 at 08:38 PM |
opps!
double list
