Author: Subject: Choosing a BEC engine
tegwin
posted on 3/2/08 at 10:25 AM Reply With Quote
Im trying to decide which bike engine to go for, im running on a budget, so the slightly older R1 engines are quite attractive, given that a decent ZZR1400 is about 2.5K
I can appreciate that the ZZR engine would be amazing but its just too much....
So, how reliable is an 03 R1 in a BEC situation? Is it going to keep falling appart?
The other option is a blackbird engine from a CBR 1100...similar power to the R1, just a bit more torque, would this be ok in a bec?
If I buy a kit from a reputable source with ECU and clocks, would I need anything else to get the engine into the car?
Obviously need a prop and adapter, but are there any other big costs involved with this?
[Edited on 3/2/08 by tegwin]
imp paul
posted on 3/2/08 at 10:30 AM Reply With Quote
this mite be just the job http://cgi.ebay.co.uk/KAWASAKI-ZX12R-ZX-12-R-2002-ENGINE_W0QQitemZ150211208589QQihZ005QQcategoryZ10464QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
worX
posted on 3/2/08 at 10:33 AM Reply With Quote
I know you are obviously just at the planning stage at the moment, but try and avoid the 03/04 R1 engine specifically - they are not the best engine's to use in a BEC as they don't "lend" themselves to being in a car or sidecar although they were brilliant in the bike...
HTH
russbost
posted on 3/2/08 at 10:49 AM Reply With Quote
The Blackbird is well known for oil starvation probs on no.3 cyl - Avoid!!
Why not go for the new ZX10 engine - more power & torque than the R1 (I think?) & absolutely unburstable.
The budget choice is a pre '95 ZZR1100, no emissions & CAT issues & costs about tuppence
tegwin
posted on 3/2/08 at 11:00 AM Reply With Quote
Hmm... the kwak ZX 12R or 10R looks nice...The former has 178Hp and 134Nm of torque...Thats one hell of a lot!
hobbsy
posted on 3/2/08 at 11:31 AM Reply With Quote
Its the 04/05 to avoid in the R1 in a car.
and the 02/03 5PW (first injected one) is fine.
Just to clear that up as a previous post said 03/04.
Though someone will probably point out there were early or late registrations of both and therefore some crossover...
clanger
posted on 3/2/08 at 11:34 AM Reply With Quote
Had my eye on this. Already emailed the guy.
Just bare engine. Stuff to get it running sold separate :-((((((
worX
posted on 3/2/08 at 12:21 PM Reply With Quote
Funny, I was going to put 03/04/05!
So it was the crossover that I was referring to that it started at!
Thanks for clearing that up Dave.
posted on 3/2/08 at 01:50 PM Reply With Quote
Busa performance for half the price......... Just make sure you get all the necessary bits and pieces, otherwise it could prove costly.
Phil
tegwin
posted on 3/2/08 at 02:26 PM Reply With Quote
Silly question...
but which "necessery pieces" do you mean?
posted on 3/2/08 at 06:57 PM Reply With Quote
With the ZX12R engine the ram pipes/trumpets and air intake temp sensor are mounted in the frame and can be quite easily overlooked and forgotten. Also, the clocks, fuel pump, fuel level sender and battery box c/w relays can be used from the bike.
Phil
[Edited on 3-2-08 by Hellfire]
MB CUSTOMS
posted on 4/2/08 at 06:06 AM Reply With Quote
If you look around hard enough and i dont mean ebay as every man and his dog are on there,it is possible to pick up a light accident damaged early zx12 or hayabusa for under £1,800 take off the bits you need, sell the rest. I have just bought an 02 cosmetic damage only hayabusa 9,000 miles on the clock for £1,300.00 as the donar for a customers bec.
clanger
posted on 4/2/08 at 07:41 PM Reply With Quote
Done just that
Mine was from the Bayof E though, just lucky that every man was out looking for his dog !!!!!
