Kriss
| posted on 4/2/08 at 12:30 PM |
BEC MPG
Done a few searches on this today but cant find anything. however this must have been discussed more than once.
Spent Saturday morning at the BEC centre checking out my car and asked about MPG. Chris quoted 20 MPG but he is such a pirate on the road we know
that's the slightly lower band.
I am driving from Gatwick to Donnington in April and then doing two days on track. Wanted to know what I would expect to see on both the motorway
cruising up there, and then on track.
car is a 2003 fi R1 MK.
Is there any benefit using high octane such as optimax etc over a normal 95?
Will be two adults at all times in vehicle
Mr Whippy
| posted on 4/2/08 at 12:43 PM |
By the sound of it, Mr Jerry can is your friend
dhutch
| posted on 4/2/08 at 01:02 PM |
Otherwise the service station just up the road is a lot cheaper than buying fuel at donnington itself. And the sandwiches are a little more resonable
too!
Daniel
smart51
| posted on 4/2/08 at 01:04 PM |
My R1 BEC returns the same 32 MPG quoted by Mr Yamaha when used normally (full throttle to the red line whenever road conditions allow).
Gentle A road cruising, a rare thing, moves that into the upper 30s. On the track, I get between 20 and 22 MPG. Others quote lower figures, but I
can't comment on their accuracy.
Kriss
| posted on 4/2/08 at 01:12 PM |
smart51
is that a 2003 R1?
Remeber buying fuel at donnington before in my clio v6. not cheap!
jerry cans are out the question as i have nowhere to store one! might fill up befor each day and see how i get one !
smart51
| posted on 4/2/08 at 01:52 PM |
quote: Originally posted by Kriss
smart51
is that a 2003 R1?
No, 1998 on carbs. Custom airbox, hugh straight through silencer and rejetted to suit.
Jubal
| posted on 4/2/08 at 02:35 PM |
My car is having the same engine from Chris and I'm expecting better than the old blade used to do mpg-wise. Previously my car would do a tank
plus two 20L jerries on a track day driven hard. I never took much notice on the road so cannot really comment. It was considerably more economical
though.
If you take it steady on track you'll easily get away with a tank in the morning and one in the afternoon. Just fill up at lunch somewhere
nearby.
Guinness
| posted on 4/2/08 at 03:36 PM |
My ZZR runs at around 30mpg on a motorway run to say Donington Show or Stoneleigh, around 20mpg on a blat and 10mpg on a track day!
Mike
| posted on 4/2/08 at 04:06 PM |
Getting to / from the track shouldn't be a problem but don't under-estimate the thirst of an engine on a track day. You'll likely
struggle to get more than 10-15mpg on the track. I'd say fill up the passenger seat with Jerry Cans but doubt your passenger would be too
chuffed..... You could make up a frame that attaches to the roll bar and carries a couple of 20L Jerry cans....
| posted on 4/2/08 at 04:17 PM |
obviously you may want to take them off for the track day itself
grub
| posted on 4/2/08 at 04:50 PM |
i dont think you will need much because youll be spending all day trying to get through the noise test.????
Jubal
| posted on 4/2/08 at 04:54 PM |
Good point re Donny. I have never even bothered booking a day there due to the restrictions.
grub
| posted on 4/2/08 at 05:05 PM |
yeh me to its a long way not cheap and a full set of to??ers
McLannahan
| posted on 4/2/08 at 06:39 PM |
I used to get 120 miles to a tank in my old GSXRK2 1000. With a passenger. Driven quite sensibly!
Gixer Indy
| posted on 4/2/08 at 09:08 PM |
I must have a hole in the tank! not seen 120 yet
Flat out til you see God, then BRAKE!
Kriss
| posted on 4/2/08 at 10:14 PM |
think a refill is required on the track day then lol. or i buy a jerry and fill it there.
I am going to a tuning show which has track time. my car club gets to go on sessions. two days track though should be fun. and there will be plenty
of flanjita to dribble over when the track is not on!
welderman
| posted on 4/2/08 at 10:22 PM |
i got fed up with filling mine up so made a new ally one, holds approx 46 litres.
Thank's, Joe
I don't stalk people
jambojeef
| posted on 6/2/08 at 12:40 PM |
Last weekend I went over the tops of the North Pennines for about 60 miles of mixed driving - WOT whenever I could + a bit of cruising real mixed
hardish driving.
30mpg!
I was amazed - wouldnt have got much more than that on my VFR and certainly would have got much less in my 528i - its turning to be a practical
vehicle after all!
Now where's that sticky notepad for the windscreen..........
Geoff
