IDONTBELEIVEIT
| posted on 10/2/08 at 09:57 AM |
slave cyclinders
hi, original blackbird slave cyclinder for clutch seems to be in the way for the sprocket adaptor and prop,wondering what has been used in this
situation cheers
wayno!!
Are We There Yet, Are We There Yet!!!!
blue2cv
| posted on 10/2/08 at 10:02 AM |
I used a Westfield setup on mine
IDONTBELEIVEIT
| posted on 10/2/08 at 10:05 AM |
any idea how much blue cheers
blue2cv
| posted on 10/2/08 at 10:11 AM |
I think they were £200ish, for brkts and slave, not cheap but did save on the brain, if i can get near the rear subframe of my build tomorrow
i'll take a couple of pics for you, its getting hidden from view now with a mock up linkage for a Kliktronic shifter, Alan
itiejim
| posted on 10/2/08 at 10:26 AM |
my car has got a load of spacers holding the slave cylinder away from the engine. The actuating rod is obviously lengthened to compensate.
I will try to attach a photo.
feckn7
| posted on 11/2/08 at 07:25 AM |
I'm in the process of making a spacer out of 3mm sheet steel which will allow the slave cylinder to be rotated out of the way of the prop - it
does foul the water hose on the other side but that is flexible.
The actuator rod doesn't need to be lengthened as the clutch only needs 5mm travel and the cylinder has (at least) 10mm travel.
the only issue is going to be in bleeding as the bleed nipple is now facing downwards.
I'll attach photos once I've taken them.
feckn7
| posted on 20/2/08 at 08:21 AM |
Pictures (at last) of the adaptor plate and mods to slave cylinder.
As you can see it only just clears the prop shaft!
