Author: Subject: drive shaft bolts.
david cromie
posted on 24/10/03 at 11:26 PM Reply With Quote
drive shaft bolts.
I am using the MK gearbox adaptor and drive shaft, what is the correct bolt size to use, also I am using a lsd, what is the correct oil to use? david
Stu16v
posted on 25/10/03 at 07:06 PM Reply With Quote
Dont know about the bolt sizes, but if you are using a Sierra LSD it is just standard EP 80w/90 or similar.
