Author: Subject: Koso Set up
Adam
posted on 17/2/08 at 07:12 PM Reply With Quote
Koso Set up
Also today i have checked all the electrics... i need to setup the koso gauge but it's all a biy ouble dutch to me anybody have any tips on how to set the gauges up? One thing that caught my eye was the oil light was always on but i know there is plenty of oil in it. is this a oil level warning or oil pressue warning.
Adam
twybrow
posted on 17/2/08 at 07:23 PM Reply With Quote
It is an oil pressure warning (or whatever the sensor is that is in your engine). There is also the oil temperature gauge - but that is different again.
The diagram is quite easy to follow. It even labels the inputs as +ve or -ve so if in doubt, get the multimeter out.
My oil pressure light is on when the engine is off, and goes off a second or so after starting the engine. Have you got to grips with your engine loom? You need to make sure you are using the right wires! It took a while, but steady methodical progress can be made!
Adam
posted on 17/2/08 at 07:25 PM Reply With Quote
I think it's linked up th the oil level wire on the R1 loom (white One) i'm not sure the R1 has a oil pressure wire/sensor?
twybrow
posted on 17/2/08 at 07:47 PM Reply With Quote
Most oil systems use a low pressure switch (i think) - not knowing the R1, I would still assume it does too! When the oil level drops significantly, the pressure will drop. It is for this reason people choose to fit an oil pressure gauge, as waiting for the oil warning light to tell you it will be too late!
