graememk
posted on 24/2/08 at 11:06 PM |
TPS Megasquirt
any one used a TPS from rs like this one before ?
can anyone tell me which wire is what ?
earth
signal
5v+
[Edited on 24/2/08 by graememk]
GregSL75
posted on 24/2/08 at 11:31 PM |
Use a digital multi-meter. Switch it to measure resistance. The resistance between two of the connections will stay the same when the throttle is
moved. Find those two - one will be the +5 Vref and the other a ground. The third is the sense wire to the MegaSquirt controller. To figure out which
wire is the +5 Vref and which is the ground, connect your meter to one of those two connections and the other to the TPS sense connection.
If you read a high resistance which gets lower as you open the throttle, then disconnected wire is the one which goes to ground, the other one which
had the continuous resistance goes to the +5 Vref from the MegaSquirt EFI Controller, and the remaining wire is the TPS sense wire.
LINK
2.0 XE on GSXR TBs and Megasquirt
GregSL75
posted on 24/2/08 at 11:32 PM |
What's going on inside in case you're interested.
