Author: Subject: propshaft for fireblade
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
Building: built mk indy blade now got a cobra
posted on 3/3/08 at 05:07 PM Reply With Quote
hi there
im building an mk indy with an firblade engine and an sierra diff,
what propshaft do i need ?
and where can i get it from any recommendations?
ive got one modified for an car engine but that wont be anyuse now will it ?cheers stu
worX
posted on 3/3/08 at 05:35 PM Reply With Quote
Your modified car engine one will be (almost definitely) useless now, yes.
You can modify a normal Sierra one by cutting the end front UJ end off and then welding on a sliding UJ to mate up to a prop adapter that will bolt to your sprocket spigot.
Or you can get a TRT prop made for you. This is better as it "replaces" the cush drive offered by the rubber blocks in the Blade's rear wheel. The only small problem there (apart from the cost ) is the need to measure accurately. But this is very simply done to be honest!!!
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 3/3/08 at 05:39 PM Reply With Quote
ok cheers steve
ill have to consider my options now
stevec
posted on 3/3/08 at 05:40 PM Reply With Quote
Where are you.?
May be someone can suggest a local supplier for you.
Steve.
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 3/3/08 at 05:45 PM Reply With Quote
im in trowbridge wilts
cheers
LBMEFM
posted on 3/3/08 at 09:01 PM Reply With Quote
Give MK's a call, they can supply an exchange Fireblade/Sierra prop for £73.50 or an extra £36.50 surcharge if you have'nt a doner one.
Barry
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 4/3/08 at 10:02 AM Reply With Quote
ok that sounds reasonable
cheers
