matt.c
| posted on 7/3/08 at 10:27 PM |
Exhaust sounds
As im down to my last few pennies i though i would blow the rest of my money on a nice race can. Are there any website which i can listen to the
different exhaust cans so i can decide which i like the best?
Youtu*e sound quality is cr*p!!
Exhaust will be fitted after the SVA.
[Edited on 7/3/08 by matt.c]
mark chandler
| posted on 7/3/08 at 10:35 PM |
If money is tight then do the sensible thing, get a standard R1 can from Ebay ~£10
Drill the rivits out on the surrounds, then grind back the folded edge, and bash out the baffles.
Bit of 2 1/2" perforated tube and some wadding then repack and rivit up, all done for £25 with adeep rich sound.
Regards Mark
worX
| posted on 7/3/08 at 11:16 PM |
Similar advice to above Matt.
Go for a nice standard (read quiet!) can and have the stealth approach and qualify easily for trackdays where other BEC's struggle...
You'll also do it for reasonable money that way aswell!
blakep82
| posted on 7/3/08 at 11:56 PM |
sure the sound depends on sooooo many different factors, a website with sound clips wouldn't be much good
________________________
djtom
| posted on 8/3/08 at 01:04 AM |
I'll second Mark's advice above - cheap carbon R1 can and rip the baffles out. Converted to a straight thru with some perforated tube and
loft insulation it seems to work very nicely - even getting me through Bedford Autodrome's draconian noise regs (I do have a turbo though, so
that helps cut down on raucous exhaust noise). Still, very impressed with something that cost me £15 from ebay!
If you're after pure sound pleasure, then I recommend my old 1.7 XFlow engine running a bit rich with pops and bangs on the overrun, a
completely empty repackable silencer and the Culfail Tunnel at Lewes on a quiet Sunday. I've got a video clip somewhere but the sound is sadly
spoilt by the wind noise. We went back and forwards 6 times because it was so much fun :-)
Tom
