Author: Subject: FIA isolator
iiyama
posted on 8/3/08 at 11:56 AM Reply With Quote
FIA isolator
As i have a bike engine, do I just wire this in as per a normal bike kill switch? Or is there a little more to it then that?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
nitram38
posted on 8/3/08 at 12:22 PM Reply With Quote
I am going to wire mine so that it cuts the battery and at the same time cuts the ign Kill.
posted on 8/3/08 at 07:44 PM Reply With Quote
then you are a wiring genius!!!
I cannot see how you can do the with the standard kill switch.
But there are two types - so I can only assume you are using the more expensive has a separate contact for the igntion. (is that the one called FIA?)
iiyama
posted on 8/3/08 at 08:05 PM Reply With Quote
yup!
