Author: Subject: prop adaptor
Mark G
posted on 17/3/08 at 08:22 PM Reply With Quote
prop adaptor
I'm building an Indy with a Fireblade engine. I need to order a prop adaptor soon but do I have to get one from MK or will one from www.sprocket-adaptors.co.uk do the job?
I'm just concerned that MK have modified my prop so they know what size to make the adaptor.
Mark.
paulmw
posted on 17/3/08 at 08:28 PM Reply With Quote
I would get it from MK if they are making your prop aswell. At least you know that it will all fit
Mark G
posted on 17/3/08 at 08:35 PM Reply With Quote
this is what I was thinking. Didn't know if they would all be the same or not though.
Only thing is MK charge around £15 more. Better to be safe though.
paulmw
posted on 17/3/08 at 08:40 PM Reply With Quote
I think they only make 2 sizes anyway and MK gave me the wrong size... but an easy fix
Make sure you get the bolts from MK for the connection to the diff as they are a pain to find.
Also, the connection of the adapter to the prop can be a squeeze depending on what engine so measure and cut your bolts carefully
Paul
jimgiblett
posted on 17/3/08 at 08:57 PM Reply With Quote
I've got one of the sprocket-adaptors. Very happy with the item.
- Jim
worX
posted on 17/3/08 at 09:54 PM Reply With Quote
Give Andy a call...
AB Performance 01449 736 633
