Author: Subject: Is my Gearbox knackered?
Mark G
posted on 23/3/08 at 05:02 PM Reply With Quote
my engine is a 893 blade lump.
I fitted the gear selector arm today and with the engine switched off I went through the gears (The child in me told me too).
Only problem is that I started in N, back to 1st, then 2, 3, 4 and then it stopped.
It should be a 6 speed box, why does it stop at 4? is this just because the engine isn't running or is it broken?
Thankyou.
Mark.
melly-g
posted on 23/3/08 at 05:19 PM Reply With Quote
Its just because its not running!
Mark G
posted on 23/3/08 at 05:35 PM Reply With Quote
I was hoping that would be the answer, Thanks..
TimC
posted on 23/3/08 at 06:32 PM Reply With Quote
Turn the sprocket flange slightly and clunk.. 5th.
posted on 23/3/08 at 06:36 PM Reply With Quote
I'd be careful not to try and change gear too much without the car moving. AFAIR it puts a lateral strain on the fingers and worry it'll bend them and make gear changes tricky when you are on the move...
Mark G
posted on 23/3/08 at 07:16 PM Reply With Quote
I only did it a couple of times and didn't put any pressure on the lever, It felt pretty happy. I was just being childish as its the first time I've changed the gear since I got the engine in December.
Thanks for the warning though.
zilspeed
posted on 23/3/08 at 09:42 PM Reply With Quote
I did that tonight too.
I've had the engine two years, so doing the old gearchange thing was one of those moments that brought a smile to my face.
