Author: Subject: 4 pipes where do they go
Chris7
posted on 8/11/03 at 07:16 PM Reply With Quote
Kawasaki ZX-9C 1999
i have one pipe of the water pump a small one about 5mm where does this go .also heating system on the carbs each side what do i do with the pipes .. last but not least i have one with a small looking filter which comes from the head where does that go
I have got bens diagram which sorted everything apart from these pipes .
Thanks Chris
Jasper
posted on 8/11/03 at 07:55 PM Reply With Quote
Small pipe from water pump = check Bens diagram cos I'm sure that deals with it. I can't remember where it goes, but it's either into the carb heaters, or back into the water system.
Pipes too and from carbs heaters can be blocked at the engine block each end - and the carb heater pipes removed as you don't need them.
Two pipes from head that goes into one filter type thing - I removed these, then took the covers off from whence they came and blocked the holes into the rocker cover with 4 x 6mm stainless bolts and Araldite.
It's all worth it in the end - mine ran like a dream all day today screaming around an airfield track - there's nothing better..... yes, even that!
